my 99si b16 2 wire crank sensor and my hx harness is 3 wire
Old Aug 12, 2007 | 10:00 AM
orangeracer's Avatar
Default my 99si b16 2 wire crank sensor and my hx harness is 3 wire
what do i do......?
Old Aug 12, 2007 | 10:06 AM
Archidictus's Avatar
Unceasing Measure
Default Re: my 99si b16 2 wire crank sensor and my hx harness is 3 wire (orangeracer)
Give us more information or I'm going to make you feel very stupid.
Old Aug 12, 2007 | 10:17 AM
Default Re: my 99si b16 2 wire crank sensor and my hx harness is 3 wire (Archidictus)
it is a 96 honda hx wireing harness and a 99si b16a2 motor and trans and i dont no what to do about the 3 wires on the wireing harness to the 2 wires on the cps
Old Aug 12, 2007 | 10:21 AM
Unceasing Measure
If you're using the B16 ECU - and I hope you are - you should find a plug that fits the 2-wire crank sensor and run two new wires from the sensor to the ECU. Your other options are to try the 3-wire sensor from your HX or swap the harness for something that is compatible with the 2-wire.
KidRuthless
Mar 19, 2014 01:07 AM
Dcaustin156
Oct 28, 2013 04:03 PM
civicSIhatch93
Oct 5, 2012 06:53 PM
grvdiggaz
Mar 7, 2006 07:33 PM
cooljerk187
Oct 1, 2003 03:48 PM
