b18b on a ek
You will need it to pass OBD2 specs.
You need these existing item from you current engine:
1) Rear O2 cat sensor
2) Larger OBD2 purge valve
Also the Crankshaft Fluctuation Sensor (CKF) is needed too.
You have to change the oil pump to an OBD2A b-series to use the CKF sensor along with lower timing belt gear.
As for the ecu, you need a OBD2A LS ECU.
Good luck in the PRK
