Help! my engine is accelerating up and down
Old Aug 12, 2007 | 01:03 AM
HAZARD_1310's Avatar
Default Help! my engine is accelerating up and down
Well my car was runnin right but today I turned it on and the rpm went up and for just a bit than it stayed at 1500rpm but it wasn't stable. Anyone have any ideas on what could be the problem any ideas would help? THANKS
Old Aug 12, 2007 | 01:06 AM
VRD^don's Avatar
Default Re: Help! my engine is accelerating up and down (HAZARD_1310)
check for vaccum leaks..throttle sticking?
Old Aug 12, 2007 | 07:22 AM
I'll do that
Old Aug 12, 2007 | 08:16 AM
eg6sittingon57cs's Avatar
check your idle valve control it might be clogged id try to clean it first because that part is like 180 bucks
Old Aug 12, 2007 | 12:36 PM
Default Re: Help! my engine is accelerating up and down (eg6sittingon57cs)
wheres the idle valve control located.
I think it could be my intake manifold gasket, Could it be a reason?
Old Aug 12, 2007 | 01:00 PM
hatch b16a guy's Avatar
It is located on the back of your intake manifold should be two 12mm bolts and a plug that you have to un clip. Just cleaned mine and got read of the cel code
Old Aug 12, 2007 | 01:39 PM
its behind the intake manifold i mean try cleaning it first but the part is 180 bucks try cleaning it first
Old Aug 12, 2007 | 01:44 PM
luckii's Avatar
yea i get the same problem thanks for asking this question ha.
Old Aug 12, 2007 | 02:32 PM
Lmgrcivic's Avatar
Default Re: (luckii)
it could be the fast idle thermo valve, idle air control valve, you could have a vaccum leak somewhere.
Old Aug 13, 2007 | 07:02 PM
Default Re: (Lmgrcivic)
I found the problem it was the intake manifold gasket there was air scaping from there changed it yesturday thanks.
I got one more problem when I accelerate my car makes more noise but doesn't advace any ideas on what could it be?
Old Aug 14, 2007 | 11:58 PM
HEY and how would I clean it[IMG][/IMG]
Eddog85
Dec 30, 2008 04:42 AM
00ekcoupe
May 23, 2006 09:06 AM
89 pos
Oct 7, 2004 11:47 AM
2000Accord5sp
Dec 18, 2003 06:57 PM
PhilJ95GSR
May 6, 2002 08:47 PM
