MAP sensor
Old Aug 12, 2007 | 12:09 AM
0ldsk00lef's Avatar
Default MAP sensor
i m almost done putting a z6 in my 91 std hatch. the motor im putting in it has a throttle body mounted map sensor. i had my harnessess converted by rywire. when i put the harness on i noticed there was no plug for the map sensor. so my question is: am i going to have to wire that into my harness or is it already wired in there somehow? any help would be appreciated. thanks
Old Aug 12, 2007 | 09:21 AM
jlicrx's Avatar
Default Re: MAP sensor (0ldsk00lef)
the MAP sensor wiring is not in the engine harness on the EF - just extend the 3 wires for the MAP connector so that it will reach the throttle body and plug it in
Old Aug 12, 2007 | 07:50 PM
0ldsk00lef's Avatar
Default Re: MAP sensor (jlicrx)
where are the three wires at? are they on the firewall?
Old Aug 12, 2007 | 07:57 PM
richboi's Avatar
i dont know your setup...but i didnt run anything to the TB's MAP...I "think" that you should be good and dont have to run anythng to the TB's maps...jus try and see wat you get.
Old Aug 12, 2007 | 08:03 PM
0ldsk00lef's Avatar
Default Re: MAP sensor (richboi)
will do. thanks for your help.
Old Aug 12, 2007 | 08:10 PM
richboi's Avatar
But....do keep your map on the firewall plugged in tho...
Old Aug 20, 2007 | 06:19 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ldsk00lef &raquo;</TD></TR><TR><TD CLASS="quote">will do. thanks for your help.</TD></TR></TABLE>
let me know how this turns out because I was wondering about the same thing.
The throttle body on my B18C has a map sensor mounted to it, and there is no map sensor plug on my CRX engine harness (I also went through rywire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi &raquo;</TD></TR><TR><TD CLASS="quote">But....do keep your map on the firewall plugged in tho...</TD></TR></TABLE>
Where is the MAP sensor on EF's? Where on the firewall.
Is this it?
Old Aug 20, 2007 | 06:33 PM
msinsky14's Avatar
Default Re: MAP sensor (91.crx.si)
yea thats the map sensor, the two cylinders on the right are purge solenoids for emissions, but they arent needed.
if u have the throttle body mounted map sensor, just plug it into that one and forget the one on the firewall
Old Aug 21, 2007 | 05:43 PM
richboi's Avatar
Default Re: MAP sensor (msinsky14)
if he does that....then he has to splice up a new plug from the firewall's map .. might as well jus leave the one at the firewall on.....thats just my 2cents
Old Aug 22, 2007 | 08:55 PM
0ldsk00lef's Avatar
that is the map sensor on the firewall and what i did is i undid the little clip that i circled on the firewall in white and the wires reached no problem. also turned out my tps was on wrong. got it all fixed up and she runs like a champ now. thanks for all the help guys.
mien_civic715
Aug 22, 2010 01:36 PM
LS94tegra
Oct 13, 2008 05:17 PM
93dabeast
May 23, 2007 04:24 AM
Pooper
Oct 16, 2006 09:19 PM
ImprtRcr02
Feb 26, 2004 01:43 PM
