what ecu??
Old Jun 12, 2002 | 09:48 AM
311's Avatar
311
Default what ecu??
I have a 2nd gen jdm b16 in a 92 civic hatch and i need an ecu! Can someone please tell me what ecu's from what cars will work, and who has one. thanks.
Old Jun 12, 2002 | 11:58 AM
BoOsTeD_eK's Avatar
Default Re: what ecu?? (311)
a gsr or chipped civic ex computer.
Old Jun 12, 2002 | 12:15 PM
311's Avatar
311
Default Re: what ecu?? (BoOsTeD_eK)
will it worked with an unchipped ex ecu, but have a lower rev limit and less fuel?
that SCION girl's Avatar
brain codes are as follows ..the easiest to find = civic ex =p28 .....b16a (good luck findin this one) = p30 ....gsr=p72...
Old Jun 12, 2002 | 12:16 PM
311's Avatar
311
Default Re: what ecu?? (allmotorgurl)
and all three of those will work right?
Old Jun 12, 2002 | 12:23 PM
oldbeefcake's Avatar
yes, as long as the p72 is OBDI. chipped the p28 for full performance.
Old Jun 12, 2002 | 12:25 PM
Default Re: what ecu?? (Jun)
Your best bet is the p28 or civic ex ecu ...yes the brain will work without being chipped...but you will have a lower rev limiter and not enough fuel
Also i believe (not posititve) if you use the GSR ecu you will have to change some of your wiring ...pin locations etc
[Modified by allmotorgurl, 1:29 PM 6/12/2002]
Old Jun 12, 2002 | 12:38 PM
Katman's Avatar
if you're interested I have a P08 ecu which is basically a JDM version of a P28 for the D15B sohc vtec engine found in the EG4/VTi model. I can reprogram it for DOHC VTEC usage with a Mugen program. Hit me up if you're interested. $240 shipped.
Old Jun 12, 2002 | 02:18 PM
311's Avatar
311
Default Re: what ecu?? (Katman)
thanks for the info guys, and katman, i will let you know!
Old Jun 12, 2002 | 02:26 PM
Katman's Avatar
koo deal..
Old Jun 12, 2002 | 03:21 PM
shermanyang's Avatar
hey, i've got a P28 ecu chipped with JUN specs...i'm not sure if i want to sell it though...cause this ecu might come in handy in the near future. also got another one chipped with SPOON specs, but my buddy's using it to run his ls/vtec.
morado2185
Oct 10, 2011 02:51 PM
RedGSR
May 8, 2003 08:51 AM
VtecbOi
Mar 30, 2003 07:06 PM
Nebula
May 31, 2002 12:13 PM
