URGENT HELP!!! Car Shut Off - SRS Light Came on - Car Overheated.. WTF?!?!?!?
Old Aug 11, 2007 | 12:31 PM
m1ndless's Avatar
* B A N N E D *
Default URGENT HELP!!! Car Shut Off - SRS Light Came on - Car Overheated.. WTF?!?!?!?
So I have been driving around all day, I have put about 300 miles on since this moring, and its about 115 out today, I was driving down the street by my house coming home, and my car shut off for a second, the SRS light came on, and then my car turned back on, WTF?!? So I pulled off the road, turned it off, waited a few mins, and turned it back on, it came on no problem, but as I was driving the rest of the way home, I had my AC on, and my car started to over heat, it went about 3/4ths way up the little thing, so I turned my AC off, and it went right back down..
I am getting ready to drive to cali tomorrow, what should I do?!?!
Any Suggestions? I am not sure what is wrong with it, is it just too hot to drive or what???!
EDIT
I just popped my hood, the coolant in my resivor tank was boiling!! Do you guys think my car just got too damn hot.
Old Aug 11, 2007 | 12:49 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: URGENT HELP!!! Car Shut Off - SRS Light Came on - Car Overheated.. WTF?!?!?!? (m1ndless)
May be the alternator going out or the belt tension. The belt goes around the alternator pulley, A/C compressor pulley, and crankshaft pulley.
Old Aug 11, 2007 | 12:53 PM
DankasCivic's Avatar
I would not drive to cali if your cars doing this dont even chance it
Old Aug 11, 2007 | 03:30 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (DankasCivic)
I just took it to my mechanic, and one of my radiator fans motor went out, and it was causing my engine to get way too hot, and there is something with my compressor that has to do with proper tension on the belt, so he is fixing it, replacing the fan motor, blade, and shroud, and cleaning everything up for only $130, I love my mechanic!!
Old Aug 11, 2007 | 05:08 PM
bseriescrxsi's Avatar
Default Re: (m1ndless)
i bet...thats a killer price...seeing as the fan motor itself can run as high as 120 itself(new)
Old Aug 11, 2007 | 05:17 PM
phootbag's Avatar
Default Re: (bseriescrxsi)
What about the stalling? Ignition switch? Loose connection from battery? What did your mechanic say about that? And, you don't need to replace the blade and shroud if just the motor stopped working.
Old Aug 14, 2007 | 02:22 PM
m1ndless's Avatar
* B A N N E D *
Default Re: (phootbag)
I got my fan fixed, it was 130 for the fan+labor (90 for the fan, $40 for an hour of labor) and then he also found why my car was dying, my ignition switch went out, we took it apart and it was burnt or something, so that was $50 for the part at BAP Imports and $40 for labor. Those anti tamper screws are a PITA!!
So now my car is running great!
Old Aug 14, 2007 | 09:40 PM
phootbag's Avatar
40 bucks for hour of labor? That is low.
Old Aug 14, 2007 | 10:22 PM
yea you lucked out there....any work i don't do myself my mechanic charges me 35 and hour for labor but he charges anyone else 70-80 and hour for labor so 40 is a good price
Old Aug 15, 2007 | 01:37 PM
m1ndless's Avatar
* B A N N E D *
Yeah, he drove to my house and did the work in my garage, he only live 10 minutes away, but he didnt charge me any extra for gas or anything either.
dj-t
Jun 25, 2009 08:21 PM
umair
Dec 6, 2007 04:27 PM
BlueIntegraBoy
Aug 16, 2005 08:22 PM
mpintegra96
May 1, 2004 06:28 AM
canuck-mx6
Aug 12, 2002 08:46 AM
