rear disc brake question (searched)
Old Aug 11, 2007 | 05:11 AM
perseverance's Avatar
Default rear disc brake question (searched)
ok guys, i have a 94 ex and my friend gave me gsr rear disc brakes. i didn't get e-brake cables but i think i can get some from an em1. now the question is about the prop valve... do i have to change out my prop valve to accomodate the rear disc brakes? if so, which car can i get it from? most likely i'll be picking it up at the junkyard so i need to kno what car. would 94-01 integra prop valves work? i see those cars at the boneyard a lot so it would be cool if they did. thx for the help in advance guys.
Old Aug 11, 2007 | 07:54 AM
pkdog167's Avatar
Default Re: rear disc brake question (perseverance)
94 civic ex should come with rear disc brakes already right?????
Old Aug 11, 2007 | 11:28 PM
roastbeefrichie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">now the question is about the prop valve... do i have to change out my prop valve to accomodate the rear disc brakes?</TD></TR></TABLE>
yes, when you swap from drum to discs, it is best to use the proportioner that was meant for it. BUT it's not the end of the world...you don't have to do it right away since most of your braking is done by the front calipers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote"> if so, which car can i get it from? most likely i'll be picking it up at the junkyard so i need to kno what car. would 94-01 integra prop valves work? i see those cars at the boneyard a lot so it would be cool if they did. thx for the help in advance guys.</TD></TR></TABLE>
a non-abs 94-01 integra valve proportioner will work (40/40). also, the 90-93 integra (40/40), 88-91 crx si (35/40), 88-95 si.
https://honda-tech.com/zerothread?id=820484
&gt;&gt;pic originally posted by toEknEEg
Old Aug 11, 2007 | 11:33 PM
kuja396's Avatar
Default Re: rear disc brake question (roastbeefrichie)
Yeah its a good idea to switch the prop valve with a teggy one or equivalent. While your at it, and if you have the money and time to do it all, go ahead and get a master cylinder and brake booster of off a integra. It will help with the whole system becuase the piston inside the master cylinder is bigger (15/16 vs. i think 13/16).
Make sure that the lines that come out of the integra master cylinder look the same as yours (when i was looking for mine I noticed there were two different versions, probably for ABS and non-ABS)
Old Aug 12, 2007 | 07:22 AM
i heard the master cylinder is the same on the Ex, and some of the ex came with abs... but not many... mine didn't. so DA integra's have the prop valve i need?? perfect, i'll get one from one of those. thx for all the info guys, i think i'll put the brakes on without the prop valve and get it sometime this week. thx guys
Old Aug 12, 2007 | 07:27 AM
viskii420's Avatar
to make the break smooth u need to upgrade ur brake master cylinder
Old Aug 12, 2007 | 10:08 AM
kuja396's Avatar
Default Re: (viskii420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">i heard the master cylinder is the same on the Ex, and some of the ex came with abs... but not many... mine didn't. so DA integra's have the prop valve i need?? perfect, i'll get one from one of those. thx for all the info guys, i think i'll put the brakes on without the prop valve and get it sometime this week. thx guys</TD></TR></TABLE>
on the side of the master cylinder it will have the size it is stamped on the side. If it says 15/16 you have no need to change it. If its 13/16 I would go ahead and do it.
Old Aug 12, 2007 | 08:31 PM
well i did the swap but one of the rotors are fucked so it's making some crazy *** noise while i drive. i'm gonna buy some new rotors and pads. are ls and gsr brakes the same? i'm not exactly which ones i have cause i got them from a friend. thx for all the help guys. i'm going to the boneyard on tuesday in hunt of a prop valve. i'll also check out the brake master cylinder to make sure it's the right one,
Old Aug 13, 2007 | 11:35 PM
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote"> i'm gonna buy some new rotors and pads. are ls and gsr brakes the same? </TD></TR></TABLE>
yes, 90-01 integra (except itr) & 88-00 civic w/ rear disc calipers all share the same pads and 9.4" rotors
Old Aug 13, 2007 | 11:44 PM
valve prop for sale: http://www.hondamarketplace.co...69301
Old Aug 14, 2007 | 02:03 AM
CapnKrunch's Avatar
Default Re: (roastbeefrichie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">well i did the swap but one of the rotors are fucked so it's making some crazy *** noise while i drive. i'm gonna buy some new rotors and pads. are ls and gsr brakes the same? i'm not exactly which ones i have cause i got them from a friend. thx for all the help guys. i'm going to the boneyard on tuesday in hunt of a prop valve. i'll also check out the brake master cylinder to make sure it's the right one,</TD></TR></TABLE>
What ebrake cables did you use?
Old Aug 14, 2007 | 05:01 AM
instrument's Avatar
krunch
on my vx i used everything from a 4door integra
ebrake cables as well.
Old Aug 14, 2007 | 05:11 AM
polything's Avatar
Default Re: (kuja396)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja396 &raquo;</TD></TR><TR><TD CLASS="quote">
on the side of the master cylinder it will have the size it is stamped on the side. If it says 15/16 you have no need to change it. If its 13/16 I would go ahead and do it. </TD></TR></TABLE>
i checked mine.. it doesnt say anything (
Old Aug 14, 2007 | 08:48 AM
i used integra dc2 e-brake cables. came off my friends 5lug setup. just picked up my prop valve today from a 4door da. says 35/40 on it. loos like the bracket to mount it on the firewall may be different tho. looks like some weird torx screws holding it together... like a torx with a dot in the middle. i'm sure i'd have to change out the bracket for it to work on my eg right?
Old Aug 14, 2007 | 12:50 PM
CapnKrunch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">krunch
ebrake cables as well.</TD></TR></TABLE>
Did you have to modify them?
Old Aug 14, 2007 | 01:33 PM
hey guys... i got my prop valve from a da... and it was mounted on the pass shock tower. lookin at the bracket... it's definately different from the one on my civic but the prop valve looks the same. there's some weird looking torx screws with a dot in the middle holding on the bracket. does autozone sell a tool for that? i was trying to drill a hole in the middle of one of my torx but the bit wasn't good enough
Old Aug 15, 2007 | 10:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">i heard the master cylinder is the same on the Ex, and some of the ex came with abs... but not many... mine didn't. </TD></TR></TABLE>
rule of thumb:
Quote, originally posted by BrakeExpert&gt;&gt;"When you go to bigger caliper than use a larger piston, you are pushing more fluid through the brake lines. Therefore, you should want a larger master cylinder to push this more fluid. General rule is…with your stock Civic DX, with the stock front calipers, keep your 13/16” MC. Any bigger and your pedal will be too stiff."
*since you are doing a rear disc conversion, you will only need to upgrade your valve proprotioner. the valve prop does NOT need to be replaced right away, i know plenty of ppl who have done rr disc swaps & didn't change out their prop yet. YOU don't need to do the valve prop swap right away since most of your braking power is handled by the front brakes.
*your 93 civic ex should have 10.3" front rotors, EX calipers w/ 15/16" master cylinder. if you have 9.4" rotors, then you have DX calipers w/ a 13/16" m/c.
*op,.. i read you tried to drill out torx bolts??? aw man, don't do that! dats da wrong ones bro. the bolts you want to remove are 2 bolts on the black colored bracket, which attaches the valve prop to the firewall. if the bracket bewteen the 2 valve props look different, you can still use 1-out-of-2 of the bolts and mount it on your firewall. you're going to need a flare wrench to take the lines off too. handle the brake lines with caution, they're fragile & bend/break very easily (pita to replace lines = re-flaring). plz use extreme caution dealing with the brake fluid as well, it'll strip your paint & eat your flesh, it's toxic (next to nuclear).
again, really not a big deal if you don't replace the valve prop...your drum prop will work fine with your rr disc calipers. <U> most of your braking is done with the front brakes.</U>
Modified by roastbeefrichie at 2:12 AM 8/16/2007
Modified by roastbeefrichie at 2:14 AM 8/16/2007
Modified by roastbeefrichie at 2:25 AM 8/16/2007
Modified by roastbeefrichie at 2:31 AM 8/16/2007
Old Aug 15, 2007 | 10:24 PM
slow_cx's Avatar
I was thinking of doing this too. Is it worth the effort?
Old Aug 15, 2007 | 10:54 PM
Default Re: rear disc brake question (slow_cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_cx &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking of doing this too. Is it worth the effort?</TD></TR></TABLE>
» How-To: 1992-1995 Hatch FULL integra brake swap: lots of pics
*15/16" non abs m/c for 10.3" brake caliper
https://honda-tech.com/zerothread?id=364783
kyle2436
Feb 22, 2009 05:32 PM
93dagsr
19
Aug 12, 2008 12:54 PM
COLKEOWN
Sep 6, 2007 10:44 AM
alterdcreations
Sep 20, 2006 02:13 PM
SkRiBLaH
30
Jan 9, 2005 04:55 PM
