Code 43 question. PLease help!
Old Aug 11, 2007 | 04:10 AM
Straight_jdm's Avatar
Default Code 43 question. PLease help!
ok so i need your help. my car is throwing a code 43 which is for fuel supply system. but my check engine light only comes on on the freeway? won't turn on till i'm going about 60mph? what do you think it could be? i have a turbo D16Y8 & its a p28 ecu. Please help!
Thanks in advance!
Old Aug 11, 2007 | 09:02 AM
anybody?
Old Aug 12, 2007 | 02:54 AM
help!
Old Aug 12, 2007 | 03:01 PM
Rd91SiB18ls's Avatar
Default Re: (Straight_jdm)
When I had my ls motor in my car it had the same code,
it was't turbo. But it went away when I changed my o2 sensor.
I changed my fuel pressure regulator first but that didn't help.
good luck
Old Aug 12, 2007 | 04:06 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i had that code, and it didn't go away until i replaced my clogged up cat with a test pipe. i'd take your cat off, reset the computer, and see if it goes away. then go from there.
Old Aug 13, 2007 | 03:43 AM
i have no cat? now what?
Old Aug 13, 2007 | 09:51 AM
BIG_T's Avatar
try the 02 then look at ur main realy
Bozo_JDM
Nov 20, 2008 08:21 PM
bryanj325
Sep 19, 2008 11:11 AM
adobospoon
Oct 30, 2005 01:11 AM
btrim23
Mar 14, 2005 08:01 AM
lopey
Mar 10, 2002 12:28 AM
