Can I use this fuel injector clip?
I am trying to reinstall my stock injectors, but I cut the wires on the clips pretty short. Anyone have any ideas of how to re-use this clip or are the wires just too short? TIA
Yes you can, you can back the pins out of it, and if you have a spare harness laying about, you can back the pins out of another female connector and use them. This is the way I do engine swap wiring for people because it eliminates wire problems, and is the smarter way to do things.
https://honda-tech.com/zerothread?id=587460
That was a good thread, until the pics went away. For that clip you will need to use a pick and pull the blue casing off, once that comes out, you will be left with the two pins, and the retaining locks, which can be pulled upward with a pick slightly and the wire/pin will be free from the connector. Once you get the blue portion off, you will be able to see what I mean. The plastic retaining piece is a small flap that sits on top of the double roll if the pin, and keeps it in place. I have the best luck by pushing the metal pin upwards into the lock, and pull it out at the same time.
BoombasticSloth
Honda Civic (2001 - 2005)
Sep 20, 2015 02:41 PM
Mr. Vapor
May 7, 2005 01:03 AM
ham
Jun 15, 2004 11:55 AM
