I NEED, HELP THIS IS IT,THIS IS ALL I NEED PLEASE HELP!
Old Aug 10, 2007 | 08:10 PM
xXSilentScreamXx's Avatar
Default I NEED, HELP THIS IS IT,THIS IS ALL I NEED PLEASE HELP!
this is all i need to get my car running ..... i have all the info i just cant find answers
im asking for help one last time .... all this **** is allmost over
so my friend wired up my 2-3 wire iacv .. but it fell apart be call hey did was twist the wires together *jo*
the wires coming from the dx harness are *orange-yellow/black-blue/black*
the wires coming from the iacv plug are *red/yellow-green*
there are 3 de-pined wires that go to plug c102 on a dx harness but idk what the plug is
and i have one mystery plug that looks like an umbrella and its a female connector
and this plug on the side of my intake manifold
Old Aug 10, 2007 | 08:17 PM
97Ej6mike's Avatar
first of all... what motor, into what car?
Im assuming something was once a y7 or auto, having a 3-wire IAC.
Old Aug 10, 2007 | 08:25 PM
averyvm's Avatar
Default Re: I NEED, HELP THIS IS IT,THIS IS ALL I NEED PLEASE HELP! (xXSilentScreamXx)
That umbrelly connecter. connects to the oil pressure swith located on the back of the motor near the oil filter.
Old Aug 10, 2007 | 08:42 PM
Default Re: (97Ej6mike)
96 ek dx with a jdm h22a srry
averyvm thanks!!! 1 down
and im useing the dx harness
Old Aug 10, 2007 | 08:45 PM
ejallday's Avatar
Default Re: (xXSilentScreamXx)
will this help out?
https://honda-tech.com/zerothread?id=1863277
Old Aug 10, 2007 | 09:50 PM
Default Re: (ejallday)
did that !!! thanks did any one find out about that plug? the c102? i have the diagrams but theres no names
Old Aug 10, 2007 | 09:54 PM
alacard's Avatar
This will help with your iacv problems:
http://www.ff-squad.com/tech/w...8.jpg
That "umbrella" plug is your oil pressure sensor plug. Which is under your intake manifold, you will kind of have to dig to find.
Is that last plug a 3-pin?
Old Aug 10, 2007 | 09:55 PM
alacard's Avatar
edit: double post
Old Aug 10, 2007 | 09:56 PM
Default Re: (alacard)
no my iacv is in the front of my mani? below the throttel cable?
that other plug is on the right side?
Modified by xXSilentScreamXx at 1:20 AM 8/11/2007
Old Aug 10, 2007 | 10:06 PM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">no my iacv is in the front of my mani? below the throttel cable?
that other plug is on the right side?</TD></TR></TABLE>
Yeah, sorry I just quickly glanced at the picture, and went back to double check...I edited my post. If that plug is 3-pin, then that group of 3 wires most likely goes there. If you have a helms manual you can check the wires.
Old Aug 10, 2007 | 10:22 PM
ejallday's Avatar
say xXSilentScreamXx i pm'ed you
Old Aug 10, 2007 | 10:26 PM
idk what to say but thank you
Old Aug 10, 2007 | 10:31 PM
ejallday's Avatar
i don't know if you had one, but i did it anyway. good luck yo. sorry i couldn't be of much help.
Old Aug 10, 2007 | 11:08 PM
01_CLtypeS's Avatar
try using the macro setting on the cam the pics will come out clear, and not blurry
Old Aug 10, 2007 | 11:27 PM
jdmracer12's Avatar
last pic in the original post is the intake air temperature sensor
Old Aug 11, 2007 | 12:41 AM
Default Re: I NEED, HELP THIS IS IT,THIS IS ALL I NEED PLEASE HELP! (jdmracer12)
those mystery wires are my ckf sensor ?? weres that on an h22a?
Old Aug 11, 2007 | 08:47 AM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmracer12 &raquo;</TD></TR><TR><TD CLASS="quote">last pic in the original post is the intake air temperature sensor</TD></TR></TABLE>
Old Aug 11, 2007 | 08:55 AM
ejallday's Avatar
did any of that stuff help out yo?
Old Aug 11, 2007 | 01:28 PM
Default Re: I NEED, HELP THIS IS IT,THIS IS ALL I NEED PLEASE HELP! (ejallday)
yes thanks so much
Old Aug 11, 2007 | 01:41 PM
ejallday's Avatar
no problem.
KDvtec5757
Jul 13, 2009 04:49 PM
CRwreckz
Jan 4, 2008 07:17 PM
dirtyhatch
Dec 15, 2003 07:09 PM
DSGB.
Mar 19, 2003 09:17 AM
