bad ecu?
Old Aug 10, 2007 | 07:50 PM
hmtcrxsir's Avatar
Default bad ecu?
I jump the ECU and theres no flashing CEL. It just stays on solid CEL. I'm not sure if this means if the ECU is bad or nott. Does the CEL flash if the engine doesnt have any problems? A few days ago my ecu had code 6,10, and 20. I disconnected the battery try starting again and it wouldnt start. And I try jumping it again and this time around the CEL stays on solid. Help? Or could a bad ecu ground leads to this?
Old Aug 10, 2007 | 08:14 PM
97Ej6mike's Avatar
Well being that it is throwing those 3 codes, have you looked into the fact that there are malfunctions in your motor?
6 ECT - water temperature sensor
10 IAT - intake air temperature sensor
20 Electrical load detector
What year civic are you running, what motor and what ECU?
Old Aug 10, 2007 | 08:17 PM
hmtcrxsir's Avatar
Default Re: (97Ej6mike)
well i didnt really look into it because i suspected that the ecu might be bad and might be just throwing random codes. so i unplug the battery and when i try starting the car again it still wouldnt start and i tried jumping it again and its just a solid CEL
Old Aug 10, 2007 | 08:18 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
What year civic are you running, what motor and what ECU?</TD></TR></TABLE>
Old Aug 10, 2007 | 08:20 PM
hmtcrxsir's Avatar
93 civic si p28 d16z6
Old Aug 10, 2007 | 08:26 PM
97Ej6mike's Avatar
Then there are obviosly things wrong with those 3 things in your motor, they should not be ignored. The computer throws the code for a reason, they are malfunctioning.
Does the temp guage in your cluster read at normal operating temp?
This code isnt possibly for a p28... IAT sensors are from OBD2 motors only.
Might want to get that checked out, alternator related?
Make sure you are pulling the codes correctly
https://honda-tech.com/zerothread/1901557
Old Aug 10, 2007 | 08:29 PM
hmtcrxsir's Avatar
The ECU would throw those codes when the car doesnt start. i know how to jump the ecu correctly. but it doesnt throw the code 6,10,20 anymore. The CEL just stays on solid after i jump it.
Old Aug 10, 2007 | 08:33 PM
97Ej6mike's Avatar
Default Re: (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">i know how to jump the ecu correctly. but it doesnt throw the code 6,10,20 anymore. The CEL just stays on solid after i jump it. </TD></TR></TABLE>
You sure your making a complete connection? If your in second accessory, it will keep the CEL on, you may not be making a complete circut when jumping it. If you think it may be soemthing bad, i would bring it to the local auto place and have them pull the codes.
Old Aug 10, 2007 | 08:34 PM
hmtcrxsir's Avatar
whats second accesory?
Old Aug 10, 2007 | 08:36 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">whats second accesory?</TD></TR></TABLE>
When you turn the key forward twice, just before engaging the ignition/starter, like when you can run your radio, power accessories, heat/ac (fans rather) without the motor being on. You know, when your battery and Oil light stay on?
Old Aug 10, 2007 | 08:43 PM
hmtcrxsir's Avatar
but isnt that how you pull codes anyways by putting it to II and by connecting it with a paper clip? yeah if i were to take the paper clip out, the CEL goes away. But if i put the clip in the CEL just stays on Solid.
Old Aug 11, 2007 | 07:36 PM
b16a3delsol's Avatar
you could have fryed the computer. see if you can find a known good ecu and then try. good luck
Old Aug 11, 2007 | 07:43 PM
hmtcrxsir's Avatar
Default Re: (lsdelsol)
but if i open up the ECU and didnt notice anything fried or burnt. Does it mean it is ok?
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
peanut butter
Jan 10, 2008 09:48 AM
RACEPAK
Nov 24, 2007 02:45 PM
drumminforev
19
Oct 6, 2006 12:12 AM
