swapped motor but cluster problem
I have a 1996 civic DX, but swapped a 2000 civic DX motor in it. i used the 2000 civic wiring harness. the problem is my speedometer and rpm guage doesnt work. does anyone have any idea whats wrong?
You shouldn't be having a problem if everything is hooked up properly, and no plugs were damaged in the process. I say check your plugs for any damages/connection issues, and make sure they're on properly.
Bump for a more certain answer. I hate electrical problems.
96 is OBD2, 99-00 is obd2a, im not sure if that is the problem, to be honest im not clear on the differences on obd2 vs 2A, but im just getting that out there.
Also make sure that everything is plugged in.
Are your Fuel and Temp guage working correctly?
Undertaker1064
Jul 11, 2006 02:07 PM
