a/f meter needed for n/a?
Old Aug 10, 2007 | 08:00 AM
civicandy's Avatar
Default a/f meter needed for n/a?
I've converted my EF to obd-1, and I'm going to be using a chipped p28. Do any of you guys run a/f meters in the car for tuning, or do you just use one when you tune the car on a dyno? I bought an a/f meter to use, but I'm thinking maybe I should just sell it.
Old Aug 10, 2007 | 10:51 AM
allm0torGSR's Avatar
Default Re: a/f meter needed for n/a? (civicandy)
I just had it tuned on a dyno, I don't need to know what it is while I'm driving.
Old Aug 10, 2007 | 10:57 AM
b16_DIM's Avatar
Default Re: a/f meter needed for n/a? (allm0torGSR)
Wouldn't it be good to have it anyway. If the ratio starts to go too rich or too lean wouldn't this be indication that something is failing?
Old Aug 10, 2007 | 12:44 PM
shad0wslay3r's Avatar
I agree with b16_DIM
Old Aug 10, 2007 | 12:46 PM
98vtec's Avatar
moderator emeritus
Default Re: (shad0wslay3r)
cant street tune without one.
Old Aug 10, 2007 | 04:04 PM
civicandy's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">cant street tune without one.</TD></TR></TABLE>
That's what I'm thinking. I'll be using chrome to tune. Half of me says once it's tuned it's done. The other half agrees with you, that it is just another way to monitor the engine.
Old Aug 10, 2007 | 04:19 PM
Turbowa's Avatar
Default Re: (civicandy)
Its never a bad idea to have one mounted in the car permanet. Esp. if you plan on having alot done ie: wild cams and/or really comp. pistons
Old Aug 10, 2007 | 05:03 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">
That's what I'm thinking. I'll be using chrome to tune. Half of me says once it's tuned it's done. The other half agrees with you, that it is just another way to monitor the engine. </TD></TR></TABLE>
for future reference, its CROME
Old Aug 10, 2007 | 07:24 PM
BeniRacing's Avatar
Im currently using the PLX m300 for datalogging use on my s300. My car is an NA B20Vtec and I have it for the simple fact that I dont trust any tuner and also if something does go wrong you will be able to see it. Just an example would be if you had a leaking injector that was dumping fuel into one of the cylinders. Real quick that cylinder will be toast from the fuel washing out the oil on the cylinder wall. IMO.
Old Aug 10, 2007 | 08:44 PM
DCxMagus's Avatar
it's never a bad thing to know your A/F ratio, saved a few of my motors before from blowing up being too lean in boost.
Old Aug 10, 2007 | 11:20 PM
smileycvc's Avatar
Default Re: a/f meter needed for n/a? (DCxMagus)
Defintely a great idea. My B20 in my sig blew up becuase of a bad fuel pressure regulator. It went lean and I didnt know. Now I have an A/F gauge. I monitor that gauge more than an other gauge I have. Except speed maybe.
Old Aug 10, 2007 | 11:47 PM
sauceja's Avatar
Default Re: a/f meter needed for n/a? (smileycvc)
I leave my wideband in my car permantly. I don't even have a narrow band. I took it out completely.
Old Aug 11, 2007 | 06:59 AM
civicandy's Avatar
for future reference, its CROME</TD></TR></TABLE>
lol. i always spell it wrong! thanks for the input guys. i think it will mount my a/f meter. i was planning on putting it in the glove box.
Old Aug 11, 2007 | 09:48 AM
smileycvc's Avatar
wouldnt it be a good idea to put it somewhere you can always see it?
Old Aug 13, 2007 | 05:46 AM
civicandy's Avatar
Default Re: (smileycvc)
yes and no. i'm not a fan of having gauges and gadgets mounted in plain sight. i can drive with the glove box open for tuning.
Old Aug 13, 2007 | 06:18 AM
H9Omega's Avatar
Those a/f guages arent very accurate.. You need a wideband o2 sensor and guage and mount it somewhere easily visible.
Old Aug 13, 2007 | 06:26 AM
civicandy's Avatar
Default Re: (H9Omega)
i have a wideband sensor. it came with the plx m300 kit i have
VTECROAR96typeR
Engine Management and Tuning
20
Oct 21, 2008 06:46 PM
Panoply
Nov 3, 2007 01:42 AM
Repn Ludes
Oct 30, 2007 01:00 PM
G"UNIT
Jun 18, 2005 04:38 AM
kr
Dec 4, 2004 06:09 AM
