shifter problem
i have a 88 hatch and i changed the shifter cause previous owner cut it to make it like a short shifter and i have a stock shifter from a 92 civic i put in.once i put everything back together i notice my shifter was leaning to the left alot,so i try put it all gears everything exept for 5th n reverse was hard.to get into 5th i would have to really use sum muscle to get it in there and also reverse i check out my linkage and all seems to be straight.what could be the problem?
I have the same problem with whover owned the car before me, they cut the ****, um as for your shifter, I would look under again, and make sure that everything is connected to spec, and have someone else with you to sit in or hold the shifter str8 when u retighten everything again, sometimes when you tighten the shifter it can be off center and you won't knotice until your done, also what kind of bushings are you using?
christiantequila
Apr 13, 2008 09:51 AM
slash00R
Nov 1, 2004 07:23 PM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
