Will high performance cams affect the compression number??
Old Jun 12, 2002 | 04:47 AM
evo's Avatar
evo
New User
Default Will high performance cams affect the compression number??
As topic:
Thanks
Old Jun 12, 2002 | 04:51 AM
sackdz's Avatar
Default Re: Will high performance cams affect the compression number?? (evo)
Yes and No. No, they will not change the compression ratio, but the longer duration may change real life compression numbers slightly as air can escape the cylinder more with the larger lobes. I think.
Old Jun 12, 2002 | 05:59 AM
CHEETAH's Avatar
Default Re: Will high performance cams affect the compression number?? (sackdz)
yes, you're right, its called dynamic compression which changes from longer duration and higher lift, and especially when more overlap is degree'd using adj. cam gears.
Greg
Old Jun 12, 2002 | 03:45 PM
evo's Avatar
evo
New User
Default Re: Will high performance cams affect the compression number?? (CHEETAH)
Sorry I actually mean the Compression Test Result but I still interested the reply. Thanks!
integra123
May 10, 2006 01:05 PM
fsp31
11
Jun 7, 2005 05:18 AM
Dan GSR
Aug 27, 2004 07:15 PM
ingrate
Oct 20, 2002 03:16 PM
HX_Guy
Aug 22, 2001 02:00 PM
