Replacing 98 Civic power window regulator?
The car already has power windows but the drivers side motor is starting to go. Is this just a simple swap type of install? I'm assuming I'd just remove any bolts/screws and slap a new one in place of the old one?
Here is a Technical Service Bulletin (TSB) which shows how the window regulator is.
http://www.tegger.com/hondafaq...e.pdf
You should check that the power window switch is okay before you replace the window regulator. Also, try cleaning the rubber channels with q-tips and rubber alcohol, and then apply silicone grease or spray to the rubber channels; this may help the windows go up and down easier.
Mike's Honda
Dec 17, 2017 03:50 PM
gqskrub
Apr 19, 2016 06:43 PM
98civ98
Feb 4, 2014 02:40 PM
