GSR cluster swap.
Old Aug 9, 2007 | 06:08 AM
gursh d's Avatar
Default GSR cluster swap.
car: 91 CRX SI
motor: 94 JDM B18C
tranny: 94 Y80 w/ LSD
I'm getting a GSR cluster for obvious reasons but had a question.
Instead of de-pinning and re-wiring my stock cluster harness to work with the GSR cluster, wouldn't it be simpler to just get a GSR cluster harness and solder the wires to the e-VSS from the Y80?
Logically, it seems as simple as that. But all the write-ups I read discuss de-pinning and re-wiring to get things to work. I think it's because they are using their stock cluster harness? For example:
http://hondacrx881.tripod.com/gsrclusterswap.html
http://www.ef-honda.com/main/viewtopic.php?t=1400
https://honda-tech.com/zerothread?id=1732102
any help appreciated
Old Aug 9, 2007 | 06:32 AM
ballermc5's Avatar
Default Re: GSR cluster swap. (91.crx.si)
people de-pin their stock cluster harness connectors, and re-pin those wires into the new connectors (in your case, the GSR cluster connectors from a GSR cluster harness)
your tranny probably came with an electrical vss in it, but your oem crx cluster needs a cable vss
to make a long story short, your going to need to de-pin your crx connectors and re-pin into the gsr connectors, and some additional wiring for the electrical vss which should have a power/ground/signal wire going to it
jruiz094
Sep 16, 2010 09:01 AM
enphotography
Dec 29, 2005 06:37 PM
jdmek910
May 4, 2005 11:05 AM
importboi22
May 31, 2004 10:32 PM
