for those with progress sway bar
on the M12 bolt it says torque it to factory specs. does anyone know the torque specs? sorry if was stated before and i over read when i searched (still drugged up from wisdom teeth comming out)
do you have a chiltons manual? cuz it should say. i will look 2nite and let you know if someone hasnt already posted the answer by then
nope
got the DC2 one though hahamy tein basics are comming later today. but ill use the DIY for the torque number there. thats be great if you could tell me later
so out under my car right now, the endlinks holding on the old sway bar. im spinning the darn bolt and nut. how do i stop the bolt from spinning in the endlink so get the nut off?
so i think the bar is going to smacking my skunk2 cat back now. these are pictures of it up in the air. i dont know how much the geometry will change when i set it down, but it looks like im in a big pickle. right now its about an inch from the exhaust in a spot.
96Formula6spd
Jun 9, 2011 05:13 PM
tokyoracer
Aug 9, 2003 04:08 AM
