THE MOST GHETTO SHIZZEL
cotter pins are suppose to be there holding the shifter cables in place. paper clips can and will break due to the heat inside the engine bay. go to auto zone and buy a pack of cotter pins. its like no more then 2 bucks for an assorted pack
good luck.
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IOSUA »</TD></TR><TR><TD CLASS="quote">cotter pins are suppose to be there holding the shifter cables in place. paper clips can and will break due to the heat inside the engine bay. go to auto zone and buy a pack of cotter pins. its like no more then 2 bucks for an assorted pack
good luck.</TD></TR></TABLE>
hmmm i have clips on my axles and such never had a problem. so cotter pins have higher heat tolerence?
good luck.</TD></TR></TABLE>hmmm i have clips on my axles and such never had a problem. so cotter pins have higher heat tolerence?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">
hmmm i have clips on my axles and such never had a problem. so cotter pins have higher heat tolerence?</TD></TR></TABLE>
im not a scientist or anything.. everything has a reason bro. im pretty sure the aluminum or whatever its made out of is different. i dont know, if honda wanted "paper clips" to hold in the shifter cables in, they would of done it.
since last night ive been reading all of your posts and i have to say, you own the most ghetto rigged car in the united states. even the way you aquired the car is ghetto.
cotter pins btw
cotter pins btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">and tell your little sister to puton a shirt.</TD></TR></TABLE>
BIGBLOCKEK
Nov 13, 2004 01:16 AM
