Pic Request: Seibon Carbon Hood VSII or XT style
Old Aug 8, 2007 | 07:16 PM
Servo's Avatar
Default Pic Request: Seibon Carbon Hood VSII or XT style
Hey all,
I've been searching my brains out EVERYWHERE on the internet for a pic of either of these hoods mounted on a car. I'd really like to compare the look of a VSII to a VIS Invader hood. But I can't find any pics. This is going on a 97 Del Sol, but any pic that I could use for photoshop would be helpful. Some of the hoods w/ the same name vary from car to car. Here's the Seibon stock photos...
http://www.seiboncarbon.com/Im...I.jpg
http://www.seiboncarbon.com/Im...T.jpg
Any pics of hoods close to these would be greatly appreciated.
Old Aug 9, 2007 | 04:23 AM
Servo's Avatar
ttt
Old Aug 9, 2007 | 07:32 PM
Servo's Avatar
up up up
Old Aug 10, 2007 | 04:33 AM
Servo's Avatar
Hmm, nobody buys these hoods?
Old Aug 10, 2007 | 04:42 AM
Aushonda's Avatar
Default Re: (Servo)
Oem style man just pre ordered mine for my del dol, looks cleaner
Old Aug 10, 2007 | 04:39 PM
Servo's Avatar
Bump for pics
Old Aug 10, 2007 | 07:17 PM
Servo's Avatar
up some more...
Old Aug 10, 2007 | 07:55 PM
Loco-B's Avatar
Default Re: (Servo)
heymikey's ride with a similar hood.
but i'd take oem over these hoods anyday.
now stop bumping this thread.
Old Aug 10, 2007 | 07:58 PM
toyomatt84's Avatar
Sanji
Cardomain.com would be a better site for that kind of "modification". Honda-tech typically doesn't deal with the "ricer-style".
Old Aug 10, 2007 | 09:01 PM
Spec R's Avatar
for those types of hoods, there has to be a lip right at the front of the vent to direct the airflow upward to create a low pressure zone so the air actually escapes from under the hood.
the one on mikey's car there has a lip, and pretty much every oem hood that has a vent for exhausting heat will have a lip too (think evo)
Old Aug 11, 2007 | 04:45 AM
Servo's Avatar
Default Re: (Spec R)
Theoretically the air flow over the hood when the car is in motion will create a low pressure zone inside the hood if you have a flat vent w/ no lip. Physics are the same either way -- the vent creates a vacuum drawing hot air out of the engine bay. (This is what I need. I think OEM looks better, too.)
The pic posted is a VIS hood. I can find pics of that one everywhere. I wanted pics of the Seibon vented hoods to compare the aestetics. But it appears nobody buys this hood! So I'll probably go with the VIS.
Old Aug 11, 2007 | 04:52 AM
Servo's Avatar
Default Re: (LoCobAnaNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCobAnaNA &raquo;</TD></TR><TR><TD CLASS="quote">now stop bumping this thread.</TD></TR></TABLE>
Thanks for your kind words, but your argument is not very convincing.
Old Aug 11, 2007 | 04:59 AM
toyomatt84's Avatar
Sanji
Default Re: (Servo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">Theoretically the air flow over the hood when the car is in motion will create a low pressure zone inside the hood if you have a flat vent w/ no lip. Physics are the same either way -- the vent creates a vacuum drawing hot air out of the engine bay. (This is what I need. I think OEM looks better, too.)
The pic posted is a VIS hood. I can find pics of that one everywhere. I wanted pics of the Seibon vented hoods to compare the aestetics. But it appears nobody buys this hood! So I'll probably go with the VIS.</TD></TR></TABLE>
If you want it for cooling purposes, just buy an OEM-style CF hood, and put 1/2" spacers on the brackets near the windshield. Same effect, without the look of a cheap hood.
Old Aug 11, 2007 | 05:09 AM
Servo's Avatar
I've thought about that, but two problems...
1) IMO body seams that don't line up look waaay more cheesy than a vented hood.
2) A vent in the front 1/3 of the hood will draw heat directly off of the manifold.
This hood is for a turbo application. If I vent the hood at the rear, all of that heat will be drawn across the charge pipe/intake manifold on its way to exiting the engine bay. That is exactly where I want to eliminate heat.
Old Aug 11, 2007 | 07:06 AM
toyomatt84's Avatar
Sanji
Default Re: (Servo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Servo &raquo;</TD></TR><TR><TD CLASS="quote">I've thought about that, but two problems...
This hood is for a turbo application. If I vent the hood at the rear, all of that heat will be drawn across the charge pipe/intake manifold on its way to exiting the engine bay. That is exactly where I want to eliminate heat.</TD></TR></TABLE>
Well, if you're going to run a vented hood on a turbo setup, put the intercooler near the vent with an oil cooler fan on it.
Old Aug 13, 2007 | 12:11 PM
Servo's Avatar
That'd take a big vent to support enough flow for the intercooler. And top-mounts are never as efficient...
Old Aug 14, 2007 | 07:22 PM
Servo's Avatar
Well, I ordered a VIS. I'll probably find a pic of the Seibons, now that I'm not looking. :roll:
Old Aug 14, 2007 | 07:27 PM
Spec R's Avatar
the spacers thing in the back doesnt expel hot air though.
the air flow at the base in the windshield is a higher pressure zone than whats under the hood in that area.
do a thermal test in the area around your intake manifold (if D/B series) and come back with your results. you'll be surprised.
some people have other reasons to tilt their hood that way though. *cough cough* posers *cough cough*
Old Aug 14, 2007 | 07:31 PM
Servo's Avatar
So that would probably be caused by the steepening angle of the windshield?
Would there even be any benefit to a hood spacer?
Old Aug 14, 2007 | 07:41 PM
MAFDARK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">the spacers thing in the back doesnt expel hot air though.
some people have other reasons to tilt their hood that way though. *cough cough* posers *cough cough*</TD></TR></TABLE>
True (in most cases).
Im in for pictures of these hoods. Honestly I would love it if they made one of the JGTC style vented ones for the sol. Im considering cutting up my OEM carbon fiber one....
ricoswav86
Sep 28, 2008 10:48 AM
jays01
Jan 24, 2008 03:26 AM
rizen
Aug 18, 2006 05:05 AM
ElectronBlueGSR
10
Nov 10, 2002 08:00 PM
IN VTEC
May 28, 2002 11:42 AM
