help with oil in the hot side of the turbo and smoking bad
is it ok to put a restrictor on a gt35r turbo ...i have no restrictor .. i read some where not to becuase its a bb turbo
if it's ok to put on a restrictor , where can i get one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radeon »</TD></TR><TR><TD CLASS="quote">is it ok to put a restrictor on a gt35r turbo ...i have no restrictor .. i read some where not to becuase its a bb turbo
if it's ok to put on a restrictor , where can i get one?</TD></TR></TABLE>
All GT turbos should have a built in oil restrictor so you know, but sometimes that does not take car of the problem alone cause our cars see such a high oil pressure.
I do believe you can add another one, I dont see why it would be a problem but someone feel free to correct me on that if things have changed.
You have a couple options... inline/ inlet fitting restrictor or inlet flange with restrictor.
Here is a -3AN inlet flange with restrictor.
http://cgi.ebay.com/ebaymotors...wItem
Here is a -4AN inlet flange with restrictor.
Here is a GT restrictor fitting from atpturbo.
http://www.atpturbo.com/Mercha...-OIL1
Here is another restrictor fitting atpturbo has.
92redhatch
Aug 20, 2009 02:32 PM
