HID ballast
depends on how long the wires are. make a watertight box to hold them then you can mount them anywhere.
make sure to keep them away from heat, water, and debris and you'll be fine. on civics i think if you remove the front bumper cover and mount them on or in the impact bar would be a good spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">depends on how long the wires are. make a watertight box to hold them then you can mount them anywhere.
make sure to keep them away from heat, water, and debris and you'll be fine. on civics i think if you remove the front bumper cover and mount them on or in the impact bar would be a good spot.</TD></TR></TABLE>
x2. worked for me.
x2. worked for me.
VTECROAR96typeR
43
Jun 18, 2009 11:27 PM
