clear coat drying weird?
got a spray can and clear from automotive touch up, the red went on fine but when the clear started to dry its leaving a bunch of rough spots and looks crystaly??
i cleaned, wetsanded, cleaned again before i painted it.
how long does the clearcoat take to dry? should i just wetsand it with 1000+grit and clear it again?
Modified by zunt at 4:17 PM 8/8/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 »</TD></TR><TR><TD CLASS="quote">What did you cleaned it with???</TD></TR></TABLE>
water/soap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 »</TD></TR><TR><TD CLASS="quote">Did you give the clear some flash time between coats????Please,post pictures to see more of the problem</TD></TR></TABLE>
i waited 6-7 mins in between coats. I will try to get pics soon
water/soap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 »</TD></TR><TR><TD CLASS="quote">clear coat should dry within, 5mins between each coat.</TD></TR></TABLE>You mean it should flash in 5 mins??? I have never had clear dry in 5 mins and it turn out to be anything i would tell anyone about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zunt »</TD></TR><TR><TD CLASS="quote">got a spray can and clear from automotive touch up, the red went on fine but when the clear started to dry its leaving a bunch of rough spots and looks crystaly??
Modified by zunt at 4:17 PM 8/8/2007</TD></TR></TABLE>
How far away were you when spraying the clear? It's possible you were putting it on too dry, you want to put clear on a bit heavier than base. Also read the can and see if they have a flash time between coats, and make sure to follow it. Some clears are 2-3 mins flash, others can be 10-15 min flash, it all depends.
alright did a little work. I wetsanded the lip with 1000 then 2000 grit. the crystaly look is now gone and its all smooth.
Thing is, the paint looks a little dull now after i washed it. Will clear make it that much more shiny?
Also does it matter what brand clear i use? im pretty much out of automotivetouchup clear
