clear coat drying weird?
Old Aug 8, 2007 | 03:06 PM
ziptie's Avatar
Default clear coat drying weird?
got a spray can and clear from automotive touch up, the red went on fine but when the clear started to dry its leaving a bunch of rough spots and looks crystaly??
i cleaned, wetsanded, cleaned again before i painted it.
how long does the clearcoat take to dry? should i just wetsand it with 1000+grit and clear it again?
Modified by zunt at 4:17 PM 8/8/2007
Old Aug 8, 2007 | 04:41 PM
blue2000em1's Avatar
Default Re: clear coat drying weird? (zunt)
What did you cleaned it with???
Old Aug 8, 2007 | 04:42 PM
Default Re: clear coat drying weird? (blue2000em1)
Did you give the clear some flash time between coats????Please,post pictures to see more of the problem
Old Aug 8, 2007 | 04:46 PM
Did you use pre paint cleaner or wax remover??
Old Aug 8, 2007 | 04:47 PM
clear coat should dry within, 5mins between each coat.
Old Aug 8, 2007 | 04:50 PM
ziptie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">What did you cleaned it with???</TD></TR></TABLE>
water/soap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">Did you give the clear some flash time between coats????Please,post pictures to see more of the problem</TD></TR></TABLE>
i waited 6-7 mins in between coats. I will try to get pics soon
Old Aug 8, 2007 | 05:10 PM
Bigblockhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">clear coat should dry within, 5mins between each coat.</TD></TR></TABLE>You mean it should flash in 5 mins??? I have never had clear dry in 5 mins and it turn out to be anything i would tell anyone about
Old Aug 8, 2007 | 05:17 PM
Unique Artwerkz's Avatar
Ive had the same problem...I just sanded it with 1000 evenly, then wet sanded it with 1500, cleaned the surface of any sanding then resprayed. Came out fine then.
Old Aug 9, 2007 | 04:19 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zunt &raquo;</TD></TR><TR><TD CLASS="quote">got a spray can and clear from automotive touch up, the red went on fine but when the clear started to dry its leaving a bunch of rough spots and looks crystaly??
Modified by zunt at 4:17 PM 8/8/2007</TD></TR></TABLE>
How far away were you when spraying the clear? It's possible you were putting it on too dry, you want to put clear on a bit heavier than base. Also read the can and see if they have a flash time between coats, and make sure to follow it. Some clears are 2-3 mins flash, others can be 10-15 min flash, it all depends.
Old Aug 10, 2007 | 11:52 AM
ziptie's Avatar
Default Re: clear coat drying weird? (WihaSi)
alright did a little work. I wetsanded the lip with 1000 then 2000 grit. the crystaly look is now gone and its all smooth.
Thing is, the paint looks a little dull now after i washed it. Will clear make it that much more shiny?
Also does it matter what brand clear i use? im pretty much out of automotivetouchup clear
UCLA.lion
Sep 17, 2006 02:41 PM
krazyhmongboi
Sep 11, 2006 12:30 AM
Vitesse
Jul 21, 2006 06:26 AM
tranquil
Oct 30, 2004 03:53 PM
mrmonk
Apr 15, 2004 11:08 PM
