Has anyone done a self valve adjustment and ignition timing before??
Old Jun 11, 2002 | 09:15 PM
SEVENSIX's Avatar
Default Has anyone done a self valve adjustment and ignition timing job before??
Just wondering if anyone has done a valve adjustment and ignition timing job for themselves.
I have read the Hayes manual on adjusting Valves and Timing.
Its been over 3 years since these things were checked and adjusted by Honda($$$ never again), I want to do it this week.
Anyone have any warnings or comments they would like to add.
It looks relatively simple...
Should I be using the Helms manual for a more precise instructional aid?
Is it neccessary be using a special wrench to losen and turn the distributer to adjust timing?
Any help will be appreciated, Thank you
[Modified by SEVENSIX, 6:17 AM 6/12/2002]
Old Jun 11, 2002 | 09:25 PM
Madness's Avatar
Default Re: Has anyone done a self valve adjustment and ignition timing job before?? (SEVENSIX)
don't know about ignition timing
valve adj is fairly easy -- check out http://www.c-speedracing.com/howto/v...lveadjust.html
assuming you have a B-series
Old Jun 11, 2002 | 10:04 PM
SEVENSIX's Avatar
Default Re: Has anyone done a self valve adjustment and ignition timing job before?? (dante_420)
Actually, its the D16z motor, but the technique is the same.
Thanks for that very informative link!!
Old Jun 11, 2002 | 11:09 PM
tinkerbell's Avatar
no.
it is heaps easier on a d seires to adjust the valves,
make sure you dont set them any looser than they need to be!
HTH,
t..
Old Jun 12, 2002 | 07:31 AM
SEVENSIX's Avatar
Default Re: Has anyone done a self valve adjustment and ignition timing job before?? (tinkerbell)
Thanks for the info.
crxaddikt
Mar 8, 2013 08:06 PM
SHG_Beans
Nov 18, 2005 03:37 PM
euG3dc2r
Feb 23, 2005 03:45 AM
555R
Jan 11, 2005 05:46 PM
SH LUDE
Oct 28, 2002 08:22 PM
