fitv problem
* B A N N E D *
hey i have a b16 on my crx but i decided to put in a skunk 2 manifold everything fits well except the first idle thermo valve because that goes bolt in on the stock manifold and two hoses come out of that one from the thorttlee body and other one from the block so what i was trying to figure out is if i can just plug in both hoses together and make it one isntead of using the thermo valve. but i dont know what the thermo valve does to the car i dont know if is necesary or not so please help me out on this so i can start quicker thanks
Well, the fitv is used for cold idle control. Basically, it has coolant lines that run to it, and depending on how hot or cold the coolant is, a wax thingy will contract/expand to create a vacuum leak which increases your idle accordingly. When your car warms up, the fitv no longer affects idle, and your iacv takes over.
The only solution I can think of is upgrading to obd1. The newer computers don't need the fitv, and can control cold idle effectively with just the iacv.
* B A N N E D *
WHAT IF I KEEP THE FITV PLUG IN THE TWO HOSES BUT THE PART THAT GOES INSIDE THE MANIFOLDJUST LOOP IT PUT SOMETHING TO BLOCK THE HOLE WILL THAT BE GOOD OR JUST PUT IT LIKE THE HOSES TOGETHER????? EITHER TWO WAYS I WILL DO IT AS LONG AS IS BETTER ????
Eurasia00
Apr 22, 2002 11:37 AM
NeXtLeVeL_TyPe_R
Nov 8, 2001 01:24 PM
