97 F20B in a 93 civic Si Distributor problems
Im still having problems doing my distributor in my f20b swap. I have poisons diagram but all the wires arent the right colors and I didnt know what to do besides make a new topic. I wrote down all my wires to see if that helped anyone. I was gonna take the rotor off and trace the wires inside the distributor but the screw was too tight and I couldnt get it off so here is what I got. Any help would be much appreciated.
All numbers are like this on the plug
1234
5678
Car Harness Side (Looking at plug from open side with mounting point at top):
1)None
2)Black/Yellow Stripe
3)White/Blue Stripe
4)White
5)Yellow/Green Stripe
6)Blue/Green Stripe
7)Pink?/Blue Stripe
8)Pink, Orange, Tan???
Car Side two pin harness( Two Slots at the top with open face towards you)
1)Black/Yellow Stripe
2)Blue
Engine Side (Viewed from open plug with one tab at top and two at bottom)
1)Black
2)White/Blue Stripe
3)White
4)Black/Yellow Stripe
5)Pink, Tan/ Orange?
6)Pink/Blue
7)Light Blue
8)Yellow/Green Stripe
1234
5678
1)None
3)White/Blue Stripe
4)White
6)Blue/Green Stripe
7)Pink?/Blue Stripe
2)Blue
1)Black
2)White/Blue Stripe
3)White
6)Pink/Blue
7)Light Blue
https://honda-tech.com/zerothread?id=1875909
Well I found this, looks like all the obd1 colors are the same but a few dont match on the obd2 side. Anyone know what to do about that?
what i ended up doing was not paying any attention to wire colors on the F dizzy, I just traced them by function and connected them to the stock locations.
look at a stock dizzy internals next to the f20 dizzy internals and make notes on color/function. You'll need to know what the various parts of the distributor are tho.
Like I said I was going to do that but I starte to strip that philips screw when taking off the rotor but I guess Ill see what I can do tonight
