z6 piston toss up
Old Aug 7, 2007 | 06:55 PM
lunch_box_4_life's Avatar
Default z6 piston toss up
so i'm rebuilding my d16 z6 and i'm wanting to up the compression
I'm thinking about using pm6 pistons
i need a bore should i go .020 over or .040 over
any help would be helpful
Old Aug 7, 2007 | 07:03 PM
1995Civic's Avatar
Need more info.
Are you planning to go all-motor?
Horsepower goals?
Street/track driven?
Stock sleeves?
Old Aug 8, 2007 | 12:37 AM
Mista Bone's Avatar
D Tranny Guru
no need for PM6's cheaper to mill the head .040"
You could run PM3's, would need to check valve clearance with the different location of the valve reliefs, That would be good for 11.7:1 compression.
Old Aug 8, 2007 | 06:35 AM
Default Re: z6 piston toss up (lunch_box_4_life)
stock sleeves
daily driver
must use pump gas (93)
another thing will this require a tune or will a stock ecu program work
Old Aug 8, 2007 | 06:38 AM
Jakester9500's Avatar
tune it
Old Aug 8, 2007 | 06:45 AM
Toroke's Avatar
Default Re: (Jakester9500)
So it's going to be an N/A daily driver? Or will you turbo it some day? The reason we're asking is because you actually want to lower compression if you're gonna boost it. If you're just looking to make a few extra horsepower and go N/A, that's different.
Old Aug 8, 2007 | 07:05 AM
Default Re: (Toroke)
Do you actually have a number in mind as for what you are shooting for in terms of compression ratio? That might help to clear some things up as well.
Old Aug 8, 2007 | 08:39 AM
basically i was thinking about 11:1 but i don;t know wear that number came from
i just want max compression but still on pump gas
n/a daily driver i'd like to make some more ponies but i don't want to
compromise reliably because it's my only car
so to sum it up most ponies lest money but reliable on pump gas
what is the most compression you can run on pump gas?
and what is the most you can bore over on stock z6 block and sleeves
137000 miles
Modified by lunch_box_4_life at 10:43 AM 8/8/2007
Old Aug 8, 2007 | 10:30 AM
Toroke's Avatar
Default Re: (lunch_box_4_life)
Well, the mileage won't matter on the block all that much since you'll be overboring (if you choose that route). But then realize that stock pistons won't fit, and you'll need something else.
Honda says not to go any more than 1mm over (or .040"). Personally, I don't want to go more than .5mm over, but I'm turbocharging it and going to be making around 300whp on a Z6. Just nice to have the extra strength. You're probably find with the 1mm over since I'm willing to bet you won't get over 160whp when all is said and done. Even that number's high, but it depends on your mods.
Old Aug 11, 2007 | 07:19 AM
any body want to comment on what kind of pistons i should use and what is the most compression i can run on pump gas
crazyassbill
Jun 8, 2009 09:03 PM
l1bid0
Dec 28, 2006 06:28 AM
Honda Crx
Nov 3, 2005 07:03 AM
jdmstreethatch
Jun 29, 2004 03:22 PM
OoHiTzToMMy
Sep 26, 2003 03:22 PM
