MSD External Coil Versus Stock Distributor CAp and Rotor
Old Aug 7, 2007 | 06:21 PM
00_EM1's Avatar
Default MSD External Coil Versus Stock Distributor CAp and Rotor
I have done mulitple searches and really found nothing. I'm looking into replacing my stock distributor cap and rotor, but my philosophy is why spend the money on regular things when I can have something better for a little bit more. I looking for the full MSD external box, more like just the regular external coil replacement.
99-00 CIVIC SI MSD CAP DISTRIBUTOR EXTERNAL COIL SS
http://cgi.ebay.com/ebaymotors...ZWDVW
Is it worth it? Or should I just save the extra money and get the OEM one?
Old Aug 7, 2007 | 10:31 PM
MikeSarr_GSR's Avatar
Default Re: MSD External Coil Versus Stock Distributor CAp and Rotor (00_EM1)
I would stick to stock unless you are at an output level where you really will see a difference over stock. I say go MSD if you are doing launch control or adding a rev-limiter that pulls spark. If this kit doesn't offer it - its debatable wether adding
this peice will really do much more than fresh stock components would.
Old Aug 8, 2007 | 05:09 AM
00_EM1's Avatar
Thanx, I'm really not pushing much power. JUst a couple of regular mods. I will probably just stick with OEM... Thank You. Also would you choose iridium spark plugs or platinum. I've heard the pros and cons of each, therefore I'm still deciding and still want more info
Old Aug 8, 2007 | 07:17 AM
all-mtr-teg's Avatar
Default Re: (00_EM1)
I went external coil, biggest headache and mistake i've made thus far. I just bought a used oem dist. so i can go back to stock setup.
Old Aug 8, 2007 | 09:52 AM
pomansouth01's Avatar
Ginger Kid
I too had to go back to stock!! and as far as the sparkplug get the copper v-power plugs...they work best...
Old Aug 8, 2007 | 03:55 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (pomansouth01)
I've run the external MSD coil system similar to the one shown for years without any problems at all.
Old Aug 9, 2007 | 12:10 AM
Default Re: (00Red_SiR)
definately something a strong motor with a nitrous system can benefit from
Old Aug 9, 2007 | 03:14 AM
mgags7's Avatar
FWIW, the stock ignition systems are good for like 350hp in preludes, I don't know if you guys' civic stuff is any different, but there is absolutely no difference until you hit that mark in a lude.
Old Aug 9, 2007 | 11:10 AM
Rice-aronie's Avatar
Default Re: (mgags7)
I went with an external coil because my stock coil died and it costs like $100 from the dealer and I just dont trust those parts from Kragen and Pepboys. Just bought a MSD external coil for $30. Done cheap fix.
Old Aug 15, 2007 | 10:13 PM
MamaLlamaSamba's Avatar
Default Re: (Rice-aronie)
im runnin pretty close to the same setup, full msd. i barely noticed difference. its an auto and the msd made it shift smoother, that was honestly the biggest difference. im sure it will help aftera certain point but on a close to stock motor it wont make much difference. also make sure you get the right distributor cap if you peice it together. plus it was a PITA to install, to me at least.
xlusiveracer
44
Apr 3, 2018 04:59 PM
xlusiveracer
Feb 3, 2018 07:03 PM
plugger
Feb 23, 2012 07:17 PM
93solcontender
Mar 9, 2003 02:33 AM
CBR
Apr 10, 2002 08:44 AM
