air conditioning question
Old Aug 7, 2007 | 03:42 PM
grg3135's Avatar
Default air conditioning question
sorry if this has been posted a billion times, if i buy a swapped car (b-series into...mid 90's civic) with no a/c, do i need a/c equiptment to match the car or the engine?
Old Aug 7, 2007 | 04:21 PM
97Ej6mike's Avatar
You will need the A/C compressor specifically for a B-series motor.
Old Aug 7, 2007 | 04:52 PM
grg3135's Avatar
Default Re: (97Ej6mike)
what about the rest of it, will the mounts from the b-series work in the civic? or do i need the whole setup from the civic and the b-series compressor? would they work together? or the whole b-series setup with civic mounts? would that work?
Old Aug 7, 2007 | 05:44 PM
grg3135's Avatar
anyone?
Old Aug 7, 2007 | 09:58 PM
grg3135's Avatar
would it work if i used everything from the original car except the compressor, and used a b-series compressor, would that work?
Old Aug 7, 2007 | 11:47 PM
grg3135's Avatar
Default Re: (grg3135)
hmmmmm?
Old Aug 8, 2007 | 02:32 AM
grg3135's Avatar
anybody?
Old Aug 8, 2007 | 08:45 AM
grg3135's Avatar
bump
Old Aug 8, 2007 | 10:29 AM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">You will need the A/C compressor specifically for a B-series motor.</TD></TR></TABLE>
No- you want to get either a p54 or a crv ac compressor bracket, and then run this-
http://www.hondaautomotivepart...R+KIT
Old Aug 8, 2007 | 10:57 AM
grg3135's Avatar
Default Re: (vestalfootball72)
thanks for the help, but i was hoping to go a little cheaper if at all possible, if i found all the stock a/c parts that were original to the car from someone who had pulled them from their own car, and a compressor to go with the motor, would that work together?
Old Aug 8, 2007 | 12:44 PM
vestalfootball72
Guest
Posts: n/a
no- you want the compressor that came stock with the d series. im in the same boat as you- i want to retrofit ac. What im doing is buying the bracket then finding someone who pulled theirs, and using everything except the bracket
Old Aug 8, 2007 | 12:46 PM
madpipr's Avatar
get a del sol vtec bracket or a crv bracket (maybe p7j). you can then use everything from a civic. compressor, condensor, drier, lines, everything.
Old Aug 8, 2007 | 12:57 PM
grg3135's Avatar
Would the del sol bracket be just for b16's? its a gsr motor so wouldnt i need the gsr bracket?
thanks for all the help guys
Old Aug 8, 2007 | 01:10 PM
crazyguy's Avatar
no gsr bracket wont work
Old Aug 8, 2007 | 01:13 PM
grg3135's Avatar
ok, just so were clear, were talking about the compressor bracket, right?
Old Aug 8, 2007 | 01:57 PM
94hatchling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grg3135 &raquo;</TD></TR><TR><TD CLASS="quote">ok, just so were clear, were talking about the compressor bracket, right?</TD></TR></TABLE>
YES. We are ALL talking about the Compressor Bracket.
The stock GSR Compressor bracket will NOT work with your stock, D-series, A/C compressor.
You're options are to use a Del Sol VTEC compressor bracket or a CRV compressor bracket with ALL stock to the car, D-series, A/C components.
Here are the parts numbers for both.
CRV - 38930-P7J-000 - $64
Del Sol - 38930-P30-000 - $104
Prices are from Majestic Honda.(Click on Name for link) Great place to find and buy cheap OEM parts.
Old Aug 8, 2007 | 03:14 PM
grg3135's Avatar
Default Re: (94hatchling)
alright, thanks a lot everyone. i really appreciate all the help
botlebruiser
Mar 7, 2006 08:57 PM
stehigs321
May 8, 2004 02:20 PM
