93 Ex motor in to a 92 CX
Old Jun 11, 2002 | 07:31 PM
CivicHB_92's Avatar
Default 93 Ex motor in to a 92 CX
Has anyone done it before? Was it hard? Anything I should look out for while doing the swap? What was the outcome? Good? Decent? No point/waste of time?
thanks
Old Jun 11, 2002 | 08:46 PM
djay86's Avatar
Default Re: 93 Ex motor in to a 92 CX (CivicHB_92)
should be quite a gain over a CX motor. but why not go all the way and do a decent b-series swap?
Old Jun 12, 2002 | 12:18 PM
CivicHB_92's Avatar
Default Re: 93 Ex motor in to a 92 CX (djay86)
I was thinkin about getting the b-series, like the LS one but i found some guy that is selling the 93 ex motor tas built just need a headgasket for 200 just the motor, what do you guys think?
Old Jun 12, 2002 | 04:28 PM
Katman's Avatar
That's cool. you should do it. It's affordable and you'll gain your own experience on engine swapping. Plus SOHC VTEC motors are fun to mess with too....cheaper than a b-series, so there's less tounge-biting if something goes arai.
Another cool thing is if you truly have a 92 civic, you will NOT need to wire up the D16Z6 (sohc vtec) engine for vtec. The VTEC wiring is already embedded in the CX wire harness at the ecu. All you need to do is make sure the guy gives you the D16Z6 engine harness + P28 ecu w/ the motor, plug it all in, and blammo you got vtec.
Is the guy selling you complete engine, trans, ecu, engine harness, all for $200? if so, it's a good deal. You can reuse your complete engine mounts, axles, and shift linkage on the D16Z6 btw, too.
Old Jun 12, 2002 | 09:16 PM
CivicHB_92's Avatar
Default Re: 93 Ex motor in to a 92 CX (Katman)
The guy is just selling the engine, but he said its completly rebuild with new pistons, rods, rings, and other things but all i need is to buy a headgasket so he can put the motor together. So all im getting is the motor for $200, then i got to go parts hunting what kind of parts should i be looking for? the 93 ex ecu? 93 ex wire harness? 93 ex axles? 93 ex shifelinkage? 93 ex....? Please help me out this would be my first swap,(yeah i kno its a little engine but it will do me good for now) Thanks to all the info
Old Jun 12, 2002 | 11:39 PM
Katman's Avatar
well if he's just selling you the long block (block & head)....
you'll need to get a 92-95 Si/EX transmission (Si & EX models use the same parts btw), a P28 ECU, and 92-95 EX/Si engine harness (or you can reuse your CX harness & just add the wires for the vtec components), and lasstly you'll need a 92-95 Si/EX exhaust manifold w/02 sensor, since the CX one is garbage.
You can reuse your CX engine mounts, shift linkage, axles, and
Old Jun 14, 2002 | 06:34 AM
CivicHB_92's Avatar
thanks for all the info
93hatch_minime
Mar 23, 2008 05:51 AM
Visionist
Jul 1, 2004 01:13 AM
vw-honda-hatches
19
Nov 30, 2002 01:25 AM
.Ryan
12
Sep 23, 2002 11:19 AM
1sick4door
Jan 22, 2002 04:47 AM
