Clutch Pedal Question
Old Jun 11, 2002 | 07:26 PM
StinkyTofu's Avatar
Default Clutch Pedal Question
Is there anyway to make my pedal more stiff? Its a little too weak for my taste.
Old Jun 11, 2002 | 07:46 PM
LostGsr's Avatar
Default Re: Clutch Pedal Question (TSK)
You can either change the pressure plate or the spring that rebound your clutch pedal.
[Modified by LostGsr, 8:46 PM 6/11/2002]
Old Jun 11, 2002 | 08:18 PM
StinkyTofu's Avatar
Default Re: Clutch Pedal Question (LostGsr)
Hm....i was hoping i could do this without changing my pressure plate.
I just felt the pedal on my friend's gsr and it was so much more stiff than mine. He has stock everything too...
Is there anything you can tighten?
Old Jun 11, 2002 | 09:43 PM
ALF's Avatar
ALF
What kind of pressure plate do you have right now?
You can also check to see if your clutch master or slave cylinder is going bad.
Old Jun 12, 2002 | 12:02 PM
BoOsTeD_eK's Avatar
Default Re: Clutch Pedal Question (ALF)
if its spaghetti soft then you might just have a bad clutch anyways.
Old Jun 12, 2002 | 01:38 PM
StinkyTofu's Avatar
Default Re: Clutch Pedal Question (BoOsTeD_eK)
Everything in my car is stock and i have 8000 miles on it. Its not like "spaghetti" soft, but i just noticed it was softer than my friend's '96 GSR.
Old Jun 12, 2002 | 02:19 PM
lightning's Avatar
As the clutch wears, the pedal will get harder to push in. Have a brand new clutch in and you will typically slam it into the floor when you engage it for the first time.
Old Jun 12, 2002 | 03:11 PM
StyleTEG's Avatar
Default Re: Clutch Pedal Question (lightning)
If there are air bubbles in the hydrolic system, that can cause the pedal to feel squishy. Try bleeding your master cylinder.
Old Jun 12, 2002 | 03:14 PM
Rocket's Avatar
Very true.
rattlecannedEF
Transmission & Drivetrain
Jun 22, 2010 01:28 AM
4drSi
Mar 28, 2007 02:59 PM
b20acura
Jan 9, 2007 10:24 AM
RTW DC2R
Jun 23, 2006 07:42 AM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
