3mm Cometic headgasket on a jdm b18c1 compression ratio?
The car will be a pig, small part due to the lower compression (3mm should go way more than 1pt), and the big part due to the fact that you loose all the quench area in the combustion chamber. I highly recommend against thick headgaskets...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 »</TD></TR><TR><TD CLASS="quote">I haven't seen many stock jdm gs-r boosted.</TD></TR></TABLE>
i had one...
i had one...
dude pretty much every honda motor has been boosted. people boost s2k's and they have some really high compression. Your not the first or even the 100th to turbo a jdm gsr motor. Tuning is critical. THE END
madman604
Jun 2, 2003 11:09 AM
