A/T P28 ..converting to M/T... any suggestions?
Old Aug 7, 2007 | 07:27 AM
jus_spooln_wicha's Avatar
Default A/T P28 ..converting to M/T... any suggestions?
i just aquired an automatic p28 ecu, and im trying to convert it to manual.. the logic that im using is comparison.. i have a manual p28 that ive been comparing resisters and deciding wich ones need to be removed from the automatic board..
both boards are identical... the only difference is the automatic has bout 10 or so more resistors .. HAS any one ever done this? of am i going in the wrong path?
any suggestions or comments are open..
Old Aug 7, 2007 | 08:19 AM
Relic1's Avatar
remove RP17 and RP18, place a jumper across RP18.
that's all that needs to be done.
Old Aug 7, 2007 | 08:36 AM
Default Re: (Relic1)
damn .. thats alot easier then what i did.. now knowing that im a little scared that i fuked it up...lol woops.. cuz i litterally cut out the resisters that were on A/T BOARD .. to look identical to the M/T BOARD..
Old Aug 7, 2007 | 08:39 AM
Default Re: (jus_spooln_wicha)
i guess thats what cha get for not researching first..
Old Aug 7, 2007 | 09:47 AM
Relic1's Avatar
the resistors that you cut out will not matter, you simply didn't have to do it.
Old Aug 7, 2007 | 10:22 AM
.. thank you for all the info, uve been alot of help !!
Old Aug 7, 2007 | 10:37 AM
instrument's Avatar
wow
a search on google would've had you the answer
but instead you just went cutting
nice!
Old Aug 7, 2007 | 04:33 PM
Default Re: (instrument)
yep it woulda been that easy ..but fortunetly i dont have a computer.. right now.. is a luxary..
92lxsleeper
Jul 17, 2009 04:05 PM
Ef9REX
Engine Management and Tuning
May 25, 2009 06:35 PM
sohcvtec66
Jan 19, 2005 03:35 AM
JinDIESEL
Jul 19, 2004 11:11 AM
da realist
Apr 25, 2004 10:57 AM
