tsi turbo kit
well i finally got this kit installed and now when im like 30% throttle or less its good under boost but when im any hire then that i can fell the engine cutting in and out anybody have the same probs and what did u do to fix it o yeah stock fuel could that be the prob
2002 civic ex 1.7a2
2002 civic ex 1.7a2
First, throw out that stupid fuel system they give you, get something better, at least an emanage with RSX injectors.
Then get rid of the missing link and use something like the e-manage voltage clamp to keep the map sensor in check.
If you're using a stock fuel system with nothing else, its pointless. Stock injectors support about 1.5 psi before they run out, and the stock ECU cant do **** for boost.
B18_Hatch
Jun 29, 2005 07:30 PM
