car only runs on 3 cylinders? dsm injector wiring w/ inline resistors?
Old Aug 6, 2007 | 05:02 PM
MBlake55's Avatar
Default car only runs on 3 cylinders? dsm injector wiring w/ inline resistors?
My car is only running on 3 cylinders and i dont really know why..........i was pulling out of burger king and i didnt even punch it, it just started bogging down and the lights were getting dimmer, but i drove it about 2 miles home going about 25 and then when i got home i noticed one of the resistors for the injector wiring was broken off. so i rewired it how it is suppose to be with the resistor going to the black and yellow signal wire on the injector clip and the harness and also got a brand new ecu with my chip in it but now it still only runs on 3 and when i unplug the injector clip the idle doesnt drop.......any suggestions? could it be that my chip just went bad? thanks
-my setup-
97' civic
built d16 w/ gt28 turbo
converted to obdI, tuned on crome w/ dsm 450s
Old Aug 7, 2007 | 08:04 AM
MBlake55's Avatar
Default Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (MBlake55)
bump anyone?
Old Aug 7, 2007 | 09:04 AM
Forty04's Avatar
I had the same issue when I was boosted. Re-soldered the injector that wasn't working, and was good to go.
You sure all your connections are solid?
Old Aug 7, 2007 | 11:10 AM
MBlake55's Avatar
Default Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (Forty04)
ya all the connections are solid but i might have the resistor on the wrong wire i have a black and yellow wire and then a red wire coming from the harness? which one gets the resistor? thanks
MBlake55's Avatar
also could something else have blown? cuz i have a brand new ecu with my chip but idk wat else could go wrong.........
Old Aug 7, 2007 | 11:57 AM
MBlake55's Avatar
bump
Old Aug 7, 2007 | 02:50 PM
MBlake55's Avatar
okay all the wiring is correct because i just checked it, from the injector wiring to the harness to the ecu.........wat else could it be?
Old Aug 7, 2007 | 03:47 PM
rpared01's Avatar
have you tried another ecu ? if you haven't try that and see if that helps
Old Aug 8, 2007 | 07:27 AM
MBlake55's Avatar
Default Re: (rpared01)
ya i have a brand new ecu
Old Aug 8, 2007 | 07:45 AM
isaacson06
Guest
Posts: n/a
the injectors could have went bad but i have only really seen dsm 450s do that or the resister went bad how old are the injectors and what are they??
Old Aug 8, 2007 | 09:32 AM
MBlake55's Avatar
Default Re: car only runs on 3 cylinders? dsm injector wiring w/ inline resistors? (isaacson06)
i have dsm 450s but how can i test them besides taking off the fuel rail and seeing if they all spray? could i hook up my stock injectors with my stock ecu and just start it to see if it runs on all 4 cylinders?
Old Aug 10, 2007 | 10:18 AM
MBlake55's Avatar
bump all the injectors are getting fuel and spraying i have spark in all 4 cylinders.........when i unplugg the injector clip for cylinder 1 the idle doesnt drop so its definitely wiring but idk where anyone?
Old Aug 18, 2007 | 08:21 AM
awadkhan's Avatar
hey m having the same isssue??.... did u resolve it... i'm having it with the RC 750z... it runs gud if u plug in the stock ones.. but goes into 3 cylinder mode on the bigger injectors.....if u resolved it do temme how??..
thanks
Old Aug 18, 2007 | 08:41 AM
95civiccpdx's Avatar
do a compression check on alll the cylinders
scooterbuilteh2
Oct 25, 2009 05:46 PM
Jayman_Gsr
Nov 21, 2008 05:18 AM
