all you need for a brand new 5-lug conversion
parts list you need for a 5-lug conversion
Ok this is it, I've been researching, reading, investigating, studying and examining to get make clear how to do a 5-lug conversion, and I mean how you'll get all you need with no doubts or having to go back and find more parts. Now looking at the price you'd end up with if you were to order new parts, I do not recommend getting new parts, 1st because there are many scrapped ITRs (Integra TypeR), 2nd looking at the price list makes me feel like I've been slapped with a hefty fine!
I am basically putting the list of parts together, big or small, although I might need some of your input to wrap it up for all to see. Links to sites who'll sell and ship to you these parts are inclusive, so then you can either take it to the mechanic or even DIY.
All parts you need are from Integra TypeR 97'-98'
It all starts here http://www.hybridautomotive.com/tech/5lug
Below are the sites you who'll sell you the parts you need, followed by part #s. Note that on some pages you'll not need all the parts, so my goal is to clear this out. Here I need some input to clarify which part numbers are required and which are not required for the conversion. Below are which I am sure of, please (if you are sure) advice which to add to or remove from the list of REQUIRED FOR CONVERSION and I'll modify accordingly:
___________________
<U>Front Lower Arm</U>
http://www.acuraoemparts.com/d...ch=no
Required for conversion list:
(pending, needs input)
<U>Brake Master Cylinder and Booster</U>
Part #26 in the diagram is the Brake Booster which you'll also need, if its not available on the same site, you'll find it here:
http://shop.acurapartstore.com...code=
<U>Rear Lower Arm</U> You'll not need all these parts (Note the 'Required Quantity' change as required)
20
21
22
23
29
33
39
<U>Front Brake Assembly</U> You'll need all the parts (Note the 'Required Quantity' change as required)
(pending, needs input, but I believe all are required)
<U>BRAKE LINES (ABS)</U> this is from a 92-93 Integra, from here I believe you only need the Porportioning Valve 4040, part# 2, which should be same as the Civic Si that you need
Finally, as I said, this is to start with initially, the list and exact part numbers will slowly be updated, depending on how much input I hope I'll be getting. Many thanks in advance
Modified by fusebox15 at 1:38 PM 8/17/2007
___________________
20
21
22
23
29
33
39
ek9grey
04-14-2007 04:34 PM
KStuned
09-09-2003 12:21 PM
