window keeps coming off track
Old Aug 6, 2007 | 04:21 PM
blinger's Avatar
Default window keeps coming off track
96 coupe .. window started coming off track, i fixed it thinking i wouldnt have the problem anymore but since then i've had the door panel off 3 more times fixing it. I'm pretty sure im doing everything right but does anyone have any info on what could be causing this or some tips or some ****? thanks
Old Aug 6, 2007 | 04:32 PM
jtfc3s's Avatar
mine kept on doing that too..i probably took out my right door panel 3 or more times coz the window kept on falling off the brackets.
i just took out the bottom screws that holds the brackets and placed eveything back together.after that the window never came off the brackets but youll just hear a loose knocking sound since nothin is holding the brackets but it aint that bad.
Old Aug 6, 2007 | 04:40 PM
foowitdaredek's Avatar
i've gone through that about a 10+ times. its no biggie i can fix it in like 10- minutes. its starting to get on my nerves. i think i might have messed up the actuator??? is that what its called? anyone know how much those go for?
..........sorry for thread jackin
Old Aug 6, 2007 | 04:44 PM
blinger's Avatar
Default Re: (jtfc3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtfc3s &raquo;</TD></TR><TR><TD CLASS="quote">mine kept on doing that too..i probably took out my right door panel 3 or more times coz the window kept on falling off the brackets.
i just took out the bottom screws that holds the brackets and placed eveything back together.after that the window never came off the brackets but youll just hear a loose knocking sound since nothin is holding the brackets but it aint that bad.</TD></TR></TABLE>
are you talking about the bolt that holds the front rail on? And are you talking about power or manual windows? my windows are manual.
Old Aug 6, 2007 | 04:55 PM
jtfc3s's Avatar
Default Re: (blinger)
oh nvm i assumed you had power windows...
i dont know if it would be the same
Old Aug 6, 2007 | 05:22 PM
blinger's Avatar
the rubber molding on the right hand side of the door (farthest from the mirror) is what i believe is causing the problem. The molding is folder under itself and not letting the window slide all the way into it. Since its not sliding into it, its easily popping back off the track.. I can't, for the life of me, figure out how to get that molding to stop folding under itself so I can slide the window into it fully
Old Aug 6, 2007 | 05:30 PM
cmasonrun's Avatar
its called a run channel, u can get them from Honda for like 75 bucks, i replaced that and the actuator on both sides and my windows feel like brand new.
Old Aug 6, 2007 | 05:43 PM
blinger's Avatar
Default Re: (cmasonrun)
75 bucks for that little rubber strip? thats ridiculous.. i'd rather have no windows then pay 75 dollars for that rubber strip. i could probably **** that strip out for cheaper
Old Aug 6, 2007 | 06:24 PM
blinger's Avatar
any way of fixing it without totally replacing it?
Old Aug 6, 2007 | 08:11 PM
like i stated above i've had the same problem even with that "run channel" what i did was i put the window back in its track rolled it up while i unfolded the run channel then i parked out in the scorching sun for a most of the day. it WAS working fine for a couple of months until yesterday!!!!
Old Aug 6, 2007 | 09:38 PM
gtlaw1's Avatar
once again I can't say it enough honda engineers deserve an aids infected ***** in their asses for this screw up
Old Aug 7, 2007 | 02:31 AM
blinger's Avatar
Default Re: (foowitdaredek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foowitdaredek &raquo;</TD></TR><TR><TD CLASS="quote">like i stated above i've had the same problem even with that "run channel" what i did was i put the window back in its track rolled it up while i unfolded the run channel then i parked out in the scorching sun for a most of the day. it WAS working fine for a couple of months until yesterday!!!! </TD></TR></TABLE>
I can't get the window completely back into the track because of the rubber piece... that is my problem
Old Aug 7, 2007 | 02:33 AM
blinger's Avatar
in having problems with the window inside the door.. the rubber is folded over in the channel that isnt visible unless u take the door panel off
Old Aug 7, 2007 | 01:36 PM
have you rolled the window down all the way?
Old Aug 7, 2007 | 01:43 PM
bpwrdeg's Avatar
Just spray a bunch of WD40 or any silicon spray down the rubber runners, seemed to help mine, if you do it weekly you shouldnt have a problem, plus using a can of WD40 is much easier than fixing it every other day...hope it helps
Bloodysnowman
May 29, 2015 03:25 PM
NightCat
11
Apr 18, 2009 03:05 PM
PatrickGSR94
Jan 5, 2008 07:47 AM
C2daIzZle
16
Sep 9, 2005 05:06 AM
hott-nix
Apr 3, 2005 04:04 PM
