Leak on passenger side.
Hey, I'm having a major water leak in my car after it rains. It's none of the seals because they were redone about 5 years ago and the windshield was just replaced. We even did a water test on top of the car so I'm thinking that it must be coming from underneath my car. The rain water builds up directly in the middle of the floor on passenger side, before the seat. I know my heat shield needs to be replaced, but I don't have a clue as to that being a factor or something else.
I have the same problem on my girlfriends 93 civic when it rains, today I took the black shroud at the bottom of the windshield off to check it out. Can't really see what the problem is but its NOT getting in through the heater. I do have a 95 gsr and undernieth the fender there is a drain coming out of the frame about 3/4 of the way up. I still cannot figure where the water is actually coming in. Any more help would be great!
ok , so I went on alldata later today and there is a TSB about this, here is the link
Body - Water Leak From Seam Under Corner of the Dash
Notes
Bulletin No.
92-050
Issue Date
FEB 3, 1997
Model [NEW]
1992 and
LATER
CIVIC
Applicable To [NEW]
ALL
File Under
BODY
Water Leak From Seam Under Corner of Dash
(Supersedes 92-050, dated May 15, 1995)
SYMPTOM
A water leak into the footwell from under the left or right corner of the dash.
PROBABLE CAUSE
Not enough sealer on the cowl side of the panel-to-bulkhead seam.
CORRECTIVE ACTION
[NEW]
Apply sealer to the seams where the side panel joins the bulkhead. Refer to section 20 of the appropriate Service Manual for removal and reinstallation of body components.
[NEW]1. Look for a leak from the lower comers of the dashboard while an assistant runs water over the windshield and cowl. Confirm which side is leaking.
[NEW]2. Remove the windshield wiper arms and the cowl cover.
[NEW]3. Remove the side sill, the inner fender, and the front fender from the side that is leaking.
4. Insert a scraping tool through the access holes, and remove all loose sealer. For better visibility, shine a flashlight through the holes.
[NEW]5. Before you reseal the seams, clean them with a wax and grease remover such as Prepsol.
6. Apply a generous amount of 3M Ultra Pro Seam Sealer (see REQUIRED MATERIALS) to the seams on the inner panel. Make sure you seal all of the seams.
NOTE : You may need to fasten a length of rubber tubing to the sealer spout when applying sealer to the upper parts of the seams.
7. Inspect the area at the bottom of the A pillar and around the hood hinge. Seal any gaps that you find in the sealer.
8. Driver's side only: Inspect the grommet around the hood release cable, and seal it if needed.
9. Retest the area for leaks.
10. Reinstall all removed parts.
REQUIRED MATERIALS
3M Ultra Pro Seam Sealer (order from 3M dealer):
P/N 051135-08302 (5 oz tube)
P/N 051135-08380 (310 ml foil pack, requires
P/N 08398 flexible applicator gun)
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Failed part: P/N 60400-SR3-A00ZZ
H/C 3886629
Defect code: 059
Contention code: B06
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
Notes
Bulletin No.
92-050
Issue Date
FEB 3, 1997
Model [NEW]
1992 and
LATER
CIVIC
Applicable To [NEW]
ALL
File Under
BODY
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
[NEW]
REQUIRED MATERIALS
In warranty:
H/C 3886629
Defect code: 059
Out of warranty:
Project T
Apr 27, 2009 04:48 AM
PatrickGSR94
Jan 30, 2005 02:38 PM
