Engine builders need your opinoin, please
I just got this block off a fellow forum junky like myself. Its an H22a4 block that had spun 2 bearings. The thrust bearing and center main.
http://is.rely.net/1-6336-8052...Q.jpg
http://is.rely.net/1-6336-8052...w.jpg
As you can see the thrust bearing dug into the journal and the ledge is almost gone.
This is what is should look like its the other side. I just got back from picking it up in California. So before I was going to spend any money on it. I wanted to get it checked out by a machine shop. The machinist told me it was junk ,as this engine uses thrust washers , if it used thrust bearing flange it might be okay. Well I would like to get more opinions on this. Before I try to talk to the guy I got it from. He had told me it was checked out and I had seen pics of the block but it didnt look that bad. The motor I plan to build is a 500 hp turbo motor and I would hate to make a mistake on the block. I'm concerned that lateral play will be to much and I'll spin a bearing or worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">junk</TD></TR></TABLE>
Not necessarily, it could be used as a coffee table or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
only if it was a b18 block.
</TD></TR></TABLE>only if it was a b18 block.
Not necessarily, it could be used as a coffee table or something. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">
my b20 block is a great coffee table in the garage kick my feet up on it all the time
</TD></TR></TABLE>my b20 block is a great coffee table in the garage kick my feet up on it all the time
93preludes
Oct 24, 2005 10:15 PM
