CTR installation in B16A: valve adjustment necessary?
Old Aug 6, 2007 | 10:38 AM
thevtecnician's Avatar
Default CTR installation in B16A: valve adjustment necessary?
I'm puttinga set of ctr cams into my boys obd0 b16a and was wondering if its necessary to adjust the valves or if we could just slap them in and go. Any help is greatly appreciated. Thank you!
Old Aug 6, 2007 | 05:39 PM
gardela's Avatar
Default Re: CTR installation in B16A: valve adjustment necessary? (thevtecnician)
if u had stock cams u dont but i always check the clearance anyway
Old Aug 6, 2007 | 07:13 PM
Jago's Avatar
Default Re: CTR installation in B16A: valve adjustment necessary? (gardela)
if your changing cams you always set valve lash
Old Aug 6, 2007 | 07:17 PM
Default Re: CTR installation in B16A: valve adjustment necessary? (Jago)
Thanks. You guys are great! Thanks for the help I better play it safe and check them. What's the worst that could happen
Old Aug 8, 2007 | 04:30 AM
stumpyf4's Avatar
Burning a valve, breaking the cam on install, cam breaking on startup.
TIP: loosen off all adjusters when installing the cam... this reduces the bending stress on the cam. Tighten the cam caps evenly, all the way down.
dustin_crxsi
Oct 12, 2006 08:05 PM
LilChuck
Mar 2, 2006 02:51 PM
blacksihatch
Oct 18, 2005 12:21 PM
hondaeg8
Oct 7, 2004 04:34 PM
