JDM D15B ECU
Old Aug 6, 2007 | 09:46 AM
jmeyer99's Avatar
Default JDM D15B ECU
Which ECU should be used for a stock JDM D15B engine?
Old Aug 6, 2007 | 09:54 AM
speedooo's Avatar
Default Re: JDM D15B ECU (jmeyer99)
p08 or p2j depending on the year
Old Aug 6, 2007 | 10:05 AM
Syndacate's Avatar
Default Re: JDM D15B ECU (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">p08 or p2j depending on the year</TD></TR></TABLE>
Yeah, but I'm sure a P28 would work just fine...may only have regular VTEC and not utilize VTEC-E, but it should run fine.
Old Aug 6, 2007 | 10:07 AM
Bense's Avatar
p28 timing is different than p08 timing.
I'd just get a chipped ecu with a p08 map
Old Aug 6, 2007 | 10:09 AM
BlackoutVTi's Avatar
Default Re: JDM D15B ECU (Syndacate)
p08=proper d15b ecu
p28=more convenient ecu to find for swappers, utilizes the four wire o2 sensor, works just as well for the one-stage vtec, chippable anyway so why not.
Old Aug 6, 2007 | 10:36 AM
Mike
Im using a a p28. No problem...
Old Aug 6, 2007 | 10:50 AM
drdanny18's Avatar
Default Re: JDM D15B ECU (Mike"IAMSLOW"Myers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike"IAMSLOW"Myers &raquo;</TD></TR><TR><TD CLASS="quote">Im using a a p28. No problem...</TD></TR></TABLE> me too
Old Aug 6, 2007 | 10:52 AM
Syndacate's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">p28 timing is different than p08 timing.
I'd just get a chipped ecu with a p08 map</TD></TR></TABLE>
Hrm, didn't know that...it works fine though.
Though yeah, I suppose you're right, a chipped OBD-I ECU with a P08 basemap is your best bet for efficiency...
94c1v1cex's Avatar
Default Re: JDM D15B ECU (drdanny18)
p28 all the way
Old Aug 6, 2007 | 11:15 AM
smileycvc's Avatar
Default Re: JDM D15B ECU (94c1v1cex)
which D15B? Vtec or Vtec-E
Old Aug 6, 2007 | 12:06 PM
jmeyer99's Avatar
Default Re: JDM D15B ECU (smileycvc)
Vtec
Old Aug 6, 2007 | 12:48 PM
95 vtec's Avatar
here could u find a po8 I am getting ready to swap my motor for the JDMd15b
Old Aug 6, 2007 | 12:58 PM
Joecivic94's Avatar
Default Re: JDM D15B ECU (95 vtec)
hey guys, im running a p28 on my D15b vtec/b7 mini me, the vtec does not work at all,i have no CEL's, the swap actually made my car a lot slower, i think i will have my po6 chipped to po8 and see if that works.
Old Aug 6, 2007 | 08:50 PM
civiceg94's Avatar
same here no problem so far
Old Aug 6, 2007 | 10:08 PM
Default Re: JDM D15B ECU (Joecivic94)
The p06 isn't even made to recognize, much less look for VTEC. It's not running properly because you now have the wrong brain for your new engine.
Old Aug 6, 2007 | 11:23 PM
SpydiR's Avatar
Default Re: JDM D15B ECU (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">The p06 isn't even made to recognize, much less look for VTEC. It's not running properly because you now have the wrong brain for your new engine.</TD></TR></TABLE>
he said 'chipped to p08' which is what I did to my p05 and it works like a champ. I also picked up a JDM P08 for just-in-case issues
Old Aug 6, 2007 | 11:53 PM
Syndacate's Avatar
Default Re: JDM D15B ECU (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">which D15B? Vtec or Vtec-E</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmeyer99 &raquo;</TD></TR><TR><TD CLASS="quote">Vtec</TD></TR></TABLE>
Eh, both.
The D15Z1 utilizes VTEC-E - which (I think) uses half the valves under ~2500 RPM or something to that effect to save fuel like **** - the "E" stands for economical.
The D16Z6 uses VTEC, which locks the rockers so higher profile cam lobes can give you a longer lift duration in the higher RPM band.
The JDM D15B utilizes both systems, it's called "3 stage VTEC" - don't ask me why it's "3" stage instead of "2" stage, I guess it's because it's VTEC-E - normal - VTEC --- a regular VTEC engine is "2 stage" I guess is how it goes - but whatever...point is:
- It's called "3 stage VTEC"
- It utilizes both VTEC-E and VTEC
Old Aug 7, 2007 | 05:54 AM
Joecivic94's Avatar
Does anybody know a good site for chipping thats cheap? thanks
Old Aug 7, 2007 | 06:57 AM
marquisdee1018's Avatar
I'm running a p08. I have a p28 but never tried it in the car.
Old Aug 7, 2007 | 08:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR &raquo;</TD></TR><TR><TD CLASS="quote">he said 'chipped to p08' </TD></TR></TABLE>
Guh. My bad.
Old Aug 7, 2007 | 08:49 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">The JDM D15B utilizes both systems, it's called "3 stage VTEC" - don't ask me why it's "3" stage instead of "2" stage, I guess it's because it's VTEC-E - normal - VTEC --- a regular VTEC engine is "2 stage" I guess is how it goes - but whatever...point is:
- It utilizes both VTEC-E and VTEC</TD></TR></TABLE>
actually no. the Z1 and Z6 are correct but the D15B can be one of four different versions that I know of. (there may be more)
or is that what you were trying to say? I'm not entirely awake yet today.
D15B nonVTEC - basically the same as our D15B7 or D15B8 I don't remember which.
D15B VTEC - basically the same as our D16Z6 but 1.5L
D15B VTEC-E - basically the same as out D15Z1
D15B three stage VTEC - OBD2 only variant, combination of Z1 and Z6 functionality. It's called three stage because the engine has three different modes, solinoids of, one solinoid on, both solinoids on.
http://asia.vtec.net/article/d15b/ is a fun read.
Old Aug 7, 2007 | 09:05 AM
drdanny18's Avatar
Default Re: JDM D15B ECU (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
http://asia.vtec.net/article/d15b/ is a fun read.</TD></TR></TABLE>
True 3 stage vtec only for the ek obd2
Ryan.
Jul 23, 2009 12:50 AM
davenport517
Mar 8, 2008 02:56 AM
jarven093
Aug 5, 2007 09:17 PM
hany
Nov 21, 2006 11:44 AM
aberfoyle
Dec 13, 2004 12:37 PM
