blue wire???
Old Aug 6, 2007 | 05:46 AM
darkwater_ghost's Avatar
Default blue wire???
not really important Just curious, on every civic I've seen from 92 up there is a blue wire located under the hood close to the firewall on the driver side next to a metal bracket that is held down by the bolts. the wire is either on or below this bracket. it also has a plastic plug on the end and sometimes with tape around the plug. does anyone know what its for?
Old Aug 6, 2007 | 05:59 AM
lo0nY's Avatar
Default Re: blue wire??? (darkwater_ghost)
it's a diagnosic plug......must installers, like me use it for a tach signal
Old Aug 13, 2007 | 10:25 AM
Default Re: blue wire??? (lo0nY)
so if i'm hooking up a tach I sould be able to use this wire?
Old Aug 13, 2007 | 10:30 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkwater_ghost &raquo;</TD></TR><TR><TD CLASS="quote">so if i'm hooking up a tach I sould be able to use this wire?</TD></TR></TABLE>
Yes, but there is also a blue wire behind your gauge cluster which you can tap into.
Old Aug 13, 2007 | 10:41 AM
Default Re: blue wire??? (BlueIntegraBoy)
yeah but I dont have to go through the cluster to install the tach. the dame thing is to big to install on the left top side of the cluster lol so where i'm running the wires will be through the side callume and to the fire wall up under the dash, clean and un noticeable.
Old Aug 13, 2007 | 05:19 PM
You can make wires run through the top small vent if you mount the tach on the dash. Just wrap with black electrical tape to make it look cleaner. You can hook up all four tach wires to the wires behind the cluster.
240sx crazy
Honda Civic (2001 - 2005)
Mar 18, 2008 05:16 AM
boosted 95 coupe
Aug 9, 2006 12:03 AM
JDM Like Whoa
22
Aug 19, 2004 10:49 AM
92'gsrhatch
Jun 2, 2003 06:37 PM
civicracer1993
Sep 17, 2002 10:53 PM
