Did A Search for tach.
Old 08-17-2004, 12:04 PM
JDM Like Whoa's Avatar
Default Already Did A Search for tach Intstall.
Was wondering if someone had a quick explanation where to wire a 5" tach. Like to what wire goes where. Thanks.
JDM Like Whoa is offline
Old 08-17-2004, 12:09 PM
any pics at all guys? Or even an explanation what wire goes to what fuse?
Old 08-17-2004, 01:48 PM
Default Re: (ImportRacr05)
Come on... Nobody knows what wires to run wherE?
Old 08-17-2004, 02:01 PM
H-T White Ops
Frozen E's Avatar
do an archive search for "tach install" in this forum.
Frozen E is offline
Old 08-17-2004, 02:18 PM
ek9800's Avatar
just get a EX/SI gauge cluster it comes with a tach and its plug and play
ek9800 is offline
Old 08-17-2004, 02:22 PM
Maybe I wanna rev a little higher than the tach goes.
Old 08-17-2004, 02:25 PM
Default Re: Already Did A Search for tach Intstall. (ImportRacr05)
http://hp.autometer.com/instru...b.pdf
Go there...you need Adobe Reader though.
PLAN:B is offline
Old 08-17-2004, 02:48 PM
Got everything but the green wire done. What does that run to. People said on the back of the instrument panel, there is a blue wire running. Would it be the one with the yellow plug that has the blue wire in it or the big longer plug with the blue wire in it.
Old 08-17-2004, 02:51 PM
I wired mine to the solid blue wire that is by the driver side fender in the top corner by the strut. I don't know which one it is in the cluster.
PLAN:B is offline
Old 08-17-2004, 02:54 PM
I looked by the fender and theres numerous wires ther.
Old 08-17-2004, 02:59 PM
Well it should be the only solid blue one. If it's not, then try all of the blue ones. Thats the fun of Do It Yourself work.
PLAN:B is offline
Old 08-17-2004, 03:06 PM
civicsicko's Avatar
it depends if you have a tach in your gauge cluster right now or not.. if you dont then its located by your right strut, by the ignition coil. it is a blue wire, that runs dead end into a rubber piece,just dig around in the wires and you should find it simply enough
civicsicko is offline
Old 08-17-2004, 03:13 PM
Well, Theres already an indash, I would like this one hooked up to go higher. Theres a yellow plug and a blue plug that go in back of the instrument panel. Both have blue wires. Which one will I get an RPM reading from?
Old 08-17-2004, 03:46 PM
Your rpm's don't go higher by plugging in an external tach.
PLAN:B is offline
Old 08-17-2004, 03:55 PM
Default Re: (mEKsican)
But no..... UGH.... I want a tach that can read more RPM's, Indash stops too early.
Old 08-17-2004, 04:18 PM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
OEM tachs are off by around 800 rpms in purpose so unaware drivers won't overrev their motors. Tap the green wire into the SOLID blue wire with a black plastic cap over it which is like a foot away from the firewall on the driver side fender.
<A HREF="http://overboost.com/pix.asp?image=./images/333/full/MVC00041.jpg
" TARGET="_blank">http://overboost.com/pix.asp?i...jpg
</A>
Feel free to ask me more questions.
Setsuna F Seiei is offline
Old 08-17-2004, 07:17 PM
K I T T's Avatar
if you still cant find the wire to tap to, go directly to the distributor and tap the wire to the (-) pole of the ignition coil. Just hide the wire into existing harnesses.
Modified by Dexter's Lab at 12:10 PM 8/18/2004
K I T T is offline
Old 08-17-2004, 07:45 PM
japspecjohn's Avatar
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">OEM tachs are off by around 800 rpms in purpose so unaware drivers won't overrev their motors.</TD></TR></TABLE>
Is that true...my old autometer was pretty close to my stock tach
japspecjohn is offline
Old 08-17-2004, 08:21 PM
got it... but in the process of setting the light... blew the clutch w00t. Exedy ceramitallic is now on order.
Old 08-18-2004, 12:25 PM
Default Re: (japspecjohn)
Depends on where you hook it up, if you tapped into the wire behind your gauge cluster where your OEM tach is at, of course it'll give you a close or similar reading, you tap directly into the ignition coil and you get a much accurate reading
Old 08-18-2004, 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">Depends on where you hook it up, if you tapped into the wire behind your gauge cluster where your OEM tach is at, of course it'll give you a close or similar reading, you tap directly into the ignition coil and you get a much accurate reading</TD></TR></TABLE>
I did it right off the coil on the dizzy....factory one was pretty accurate
Old 08-18-2004, 02:31 PM
rentacop's Avatar
You want to rev higher than 9 grand?
RICER ALERT WEE-OOOO WEE-OOOO
rentacop is offline
Old 08-19-2004, 10:49 AM
Default Re: (rentacop)
Uh huh.. Yah. Shut up. Its going to the machine shop this winter. Spoon ITR pistons, ITR shot peened rods, port and polish on the head, skunk2 cams springs and retainers, skunk2 intake manifold... more to come. New exedy clutch to put down some power.
Basically its gonna be a mild built. But I am hoping to make some power up there after tuning.
Modified by ImportRacr05 at 2:00 PM 8/19/2004
Modified by ImportRacr05 at 2:01 PM 8/19/2004
240sx crazy
Honda Civic (2001 - 2005)
03-18-2008 05:16 AM
civic_d16y7
06-30-2006 07:35 PM
joecivic93
01-06-2004 10:07 PM
civicracer1993
09-17-2002 10:53 PM
CheezeFrog
07-19-2001 07:57 AM
Quick Reply: Did A Search for tach.
  • Ask a Question
Question Title:
Description:
