Need help putting a sump on the tank
Old Aug 5, 2007 | 09:16 PM
V-SPEC 1's Avatar
Default Need help putting a sump on the tank
Hey Guys, I want to install the full-race fuel sump on my EG gas tank. What's the best way of taking the tar off the bottom of the tank? My welder wants me to remove that black tar looking thingy first before he weld my sump on there. he said he don't want to smell that crap ha! ha! Can I remove it by using scraper or maybe die grinder? Please I need your advice if you don't mind. Thank you guys.
Old Aug 5, 2007 | 09:34 PM
preludestud11's Avatar
Default Re: Need help putting a sump on the tank (V-SPEC 1)
try acetone, or a scrape, or a combitnation. you can use a die grinder bu make sure there is no gas left in the tank becuase if you get a spark yu could have a fire.
Old Aug 6, 2007 | 02:44 AM
ROTARY's Avatar
try this, you can buy it at any auto parts store.
Old Aug 6, 2007 | 05:05 AM
dfoxengr's Avatar
Default Re: (ROTARY)
and a wire wheel instead of a grinder
Old Aug 6, 2007 | 09:19 AM
Bakeoff's Avatar
wire wheel, all the way.
Old Aug 6, 2007 | 09:28 AM
V-SPEC 1's Avatar
Default Re: (Bakeoff)
Thanks for the advice guys, I'll try using that aircraft remover and probably use the wire wheel to clean it all the way off.
Old Aug 6, 2007 | 11:57 AM
*Boostwerks*'s Avatar
Default Re: (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice guys, I'll try using that aircraft remover and probably use the wire wheel to clean it all the way off. </TD></TR></TABLE>
All you really need is the wire wheel. Then just clean the bare metal with some acetone.
Old Aug 6, 2007 | 02:05 PM
ShawnR's Avatar
Default Re: (Boostwerks.com)
i used a razor blade wire wheel and some air craftstripper wasnt the funnest thing iv ever done
Old Aug 6, 2007 | 02:08 PM
allstokhonda's Avatar
all I used was one of those rough textured, red in color, grinding pads.. It took it down to bare metal in a just a few passes.. Worked great! Oh I got it at Autozone I think..
Old Aug 8, 2007 | 12:21 AM
brightside's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">try this, you can buy it at any auto parts store.
that stuff works GREAT!!! used it a little while ago, the undercoating/tar just scrapes right off. just make sure you have a trash can with a bag in it as it will make a mess if you don't have someplace to put the gunk. wire wheel works fine, but makes everything in a 10 ft. radius covered in the undercoating ( I still have a shirt with the stuff on it from like 6 monthes ago )
Old Aug 8, 2007 | 06:11 AM
AZSTATEPOLICE's Avatar
Wire wheel
Old Aug 14, 2007 | 09:16 PM
1clnef9's Avatar
Default Re: Need help putting a sump on the tank (AZSTATEPOLICE)
just go by a new gas tank there like 100 bucks
Old Aug 15, 2007 | 01:37 AM
Default Re: Need help putting a sump on the tank (1clnef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1clnef9 &raquo;</TD></TR><TR><TD CLASS="quote">just go by a new gas tank there like 100 bucks</TD></TR></TABLE>
Old Aug 15, 2007 | 04:22 AM
ShawnR's Avatar
from where?
Old Aug 15, 2007 | 12:57 PM
hybridmoments's Avatar
don't get this **** on your skin, you'll be hating life. definitely do not do this while in a thong or speedos.
and definitely make sure to not wear this shirt.
oh, and that's my modeling/stripper name. "BLACK SPARKLE"
Old Aug 15, 2007 | 06:21 PM
pro547's Avatar
Default Re: (hybridmoments)
I LOL'd
b16bri
Welding / Fabrication
Mar 29, 2011 07:30 PM
MidwestAutoWorks
Dec 3, 2008 06:11 PM
narfdanarf
53
Sep 2, 2008 07:49 PM
V-SPEC 1
Aug 16, 2007 06:16 AM
Dyno Queen
Jan 23, 2005 03:23 PM
