del sol help
Old Aug 5, 2007 | 04:44 PM
cyb593's Avatar
Default del sol help
ok what is this i cant get anyone to tell me what his does. could this be the pvc? could this impede high throttle if the tube on there was pinched? need help fast please.
Old Aug 5, 2007 | 04:46 PM
95ProjectEJ1's Avatar
Default Re: del sol help (cyb593)
I believe that is just for crankcase emissions.
Old Aug 5, 2007 | 05:00 PM
cyb593's Avatar
Default Re: del sol help (95ProjectEJ1)
could this impede on correction operation of engine?
Old Aug 5, 2007 | 05:36 PM
95sloweg's Avatar
Im not to sure what it does but on my car i have a short ram intake and where the hose is on the motor, i have a small cone air filter. I dont know if this helps you at all.
Old Aug 5, 2007 | 05:54 PM
cyb593's Avatar
Default Re: del sol help (95sloweg)
i have seen that before but i dont know if it has anything to do with the issue i am having.
Old Aug 5, 2007 | 06:08 PM
95sloweg's Avatar
Couldnt you just disconnect that hose and take it for a quick drive down the street to see if that causes your problem.
Old Aug 5, 2007 | 06:15 PM
cool_junk's Avatar
That is just the fresh air tube for the crankcase ventalation system. The pcv pulls crankcase fumes thru into the intake. fresh filtered air flows from the air filter into the crankcase and then is sucked up into the pcv.
as long as the pcv isn't stopped up you shoudn't have a drivability issue and even if it was stopped up you probably wouldn't be able to tell, ecpecially at higher rpm's.
Later, Drew
Jerekson
Dec 27, 2009 10:36 AM
tnxx
Dec 17, 2009 10:05 PM
DelSol941
Oct 11, 2003 08:34 PM
Happyman
Nov 21, 2002 03:58 PM
jonnybravo
May 23, 2002 11:38 AM
