I Need Help....
Ok here is what is up. My car started fine yesterday. But the fans were not on. So i found out it was the fan relay that was bad. Then i wanted to restart my ecu and i disconnected the hazzard and ecu fuse for 10 sec. and then plugged it back in. i might have done that with the battery connected and maybe the ignition on. I fucked up.
...and after all that. the car is not starting. I spray started fluid in the intake and it turnes over for a sec. so i dont think its the spark...i turned the key and i cannot here the fuel pump come on. so i am thinking bad fuel pump or the fuel pump relay is bad. but how could this of happened.....the car was runnning fine...i am thinking i shorted out something. please help if u can.....
i also have an integra 90 ls. is the relay fuel pump relay the same. cause i could try to take out the one on the integra and swap it real quick to see if that is the prob...
