Civic motor problems
Old Aug 5, 2007 | 09:07 AM
bigturbo's Avatar
Default Civic motor problems
I have a 94 civic with a d15bvtec jdm motor. When I first bought it, it would smoke white(sometimes blueish) just a little when you rev above 5k but the car had no cat so I thought that was the issue. I put on a cat and it has slowly started to smoke more and more. It would smoke on start up and then about 60 secs later stop unless I was in the high rpms. Now it smokes all the time. I let it run and then turned it off and pulled one of the plugs(which are brand new) and there is black all over them. I drained the oil and it was black and I looked at the coolant so it does not seem to be mixing(head gasket issue). When i changed the oil I used Lucus additive that is suppose to help seal leaky seals but it only smokes worse now. Also after the car was off there was still smoke coming out of the cylinder where I pulled the plug. I am sure its oil getting in the motor but what I am wondering is if I remove the head will I be able to physically see if the rings on the pistons are bad or if the oil is coming from somwhere else like valve seats or something?? I am not brand new to motors(have done a few motor swaps) but have not had to troubleshoot or rebuild an engine yet. Thanks everyone
Old Aug 5, 2007 | 09:59 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Civic motor problems (bigturbo)
Is there oil in the spark plug tubes?
Old Aug 5, 2007 | 12:25 PM
bigturbo's Avatar
no there is not oil in the spark plug tubes.
Old Aug 5, 2007 | 12:35 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (bigturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigturbo &raquo;</TD></TR><TR><TD CLASS="quote">no there is not oil in the spark plug tubes. </TD></TR></TABLE>
Valve stem seals then maybe. Have you done a compression or leakdown test?
Old Aug 5, 2007 | 06:50 PM
bigturbo's Avatar
I did a compression test and they were all between 125 and 130. I dont know how to do a leakdown test. Would that tell me if it were something in the head or something on the bottom end???
Old Aug 5, 2007 | 07:39 PM
yoffer's Avatar
Banned
Your rings are probably going bad. I think the compression ratio on a jdm d15 is like 9:5 so you should be getting like around 170 or so.
Old Aug 10, 2007 | 07:10 AM
bigturbo's Avatar
Man that sucks. I figured that was it but when you hope its something else so badly, you try to steer away from the bad. looks like the motor is coming out this weekend then. How hard is it to replace piston rings?? I have removed heads and replaced headgaskets before. i have also done motor swaps but never rebuilt a bottom end.
saNx
Aug 5, 2006 11:47 PM
averyvm
Jul 26, 2006 12:56 PM
omgwtfhaxnub
Apr 6, 2005 02:13 AM
Fbp00si
Jul 25, 2003 01:49 PM
MHhonda99
May 21, 2002 06:59 PM
