Horn wiring for Momo steering wheel
To what does the black wire on my Momo horn connect? I have the hard part done, the sliding connection to the brass plate, but the black wire came loose.
1 Post
It just needs to be grounded, connect it directly to the adapter, or to one of the bolts that holds down the steering wheel.
Most wheels will come with a horn ring that has a tab on it that you can easily connect it to.
Re: (monicle)
OK, there is a yellow wire from the tab on the back of the horn to the horn ring. There is a black wire from the other tab on the back of the horn. The other end of the black wire is loose. There is also a slide connection to the bras ring on the wheel.
If I touch the black wire to the bolt, the horn still does not work. I wonder if a fuse is blown...
crdcz03
09-10-2020 09:23 PM
mahatma
10
07-11-2005 08:18 AM
