H23A...No Mods....What to do?....
Old Aug 5, 2007 | 09:06 AM
hondoval's Avatar
Default H23A...No Mods....What to do?....
I run a 92 lude h23a with no mods whatsoever in the oval. The problem is that the class I run is a claiming division where my car can be purchased, with some stipulations of course, by another driver for 1000 dollars. What will get me the most bang for my buck. 1/3 mile oval, I run 2nd gear the entire time, rev out at about 7000 right before the turns, HELP!!!
hondoval's Avatar
Default Re: H23A...No Mods....What to do?.... (hondoval)
N/A ONLY!!
Old Aug 5, 2007 | 09:33 AM
InvaderTrax's Avatar
So what mods are legal? External only?
Old Aug 5, 2007 | 06:34 PM
hondoval's Avatar
Default Re: (InvaderTrax)
You can go internal, just no turbo and no supercharger, but bare in mind, you dont want to give away $2000 worth of engine mods, not to mention the rest of the car, for the $1000 claim. Its there to keep Bill Gates from deciding he wants to race and bringing a $20,000 car to the track and waxing us po-folks, and it also definitely makes you get creative.
Old Aug 5, 2007 | 06:42 PM
Hawkze_2.3's Avatar
Default Re: (hondoval)
Well, some cams + valvetrain + simple bolt-ons + tuning would be about the best thing you could do for more power on an H23.
Maybe Crower stage 2 or 3 cams, Rocket valvetrain (springs, retainers), intake, Megan header (cheap and effective), some sort of tuning device (Hondata is good but a bit overkill, Crome, etc), plus a good tune up would get you some good NA power. Also, if you can some lightweight wheels and an 8lb Fidanza flywheel would do you good.
Old Aug 5, 2007 | 06:55 PM
saikou's Avatar
... or
https://honda-tech.com/zerothread?id=1495684
Old Aug 5, 2007 | 07:01 PM
hondoval's Avatar
Default Re: (Hawkze_2.3)
What kind of problems and dinero am I looking at with an h22 head swap?
Old Aug 5, 2007 | 07:03 PM
hondoval's Avatar
And what kind of power increase could I expect by just changing to h22 pistons?
Old Aug 5, 2007 | 07:33 PM
TylerC161's Avatar
not enough to be worth it, because you'll need more then just the pistons.
correct me if im wrong
Old Aug 5, 2007 | 07:36 PM
hondoval's Avatar
Default Re: (TylerC161)
The pistons aree suppose to raise the compression to nearly 12:1 right?
Old Aug 16, 2007 | 01:07 PM
hondoval's Avatar
By the way I never see first or fouth. 1/3 mile oval.
Old Aug 16, 2007 | 01:12 PM
Finest's Avatar
So wait, if you lose, the other guy gets your car for $1k?
Old Aug 16, 2007 | 01:13 PM
Si Speed's Avatar
H23 VTEC, done properly, is more money than it's worth, at least in your position, although I've seen some nice setups. But fast, cheap, and reliable don't necesary go hand and hand. Port and polish the IM, about a 68 MM TB, simple intake, thenhead work. Crower stage 2s with the v-train upgrade (required with the cams), then tune. That much will cost enough but will get results. I also reccomend a header and exhaust. Besure to do the 2.5" collector mod on the header.
Old Aug 16, 2007 | 01:21 PM
hondoval's Avatar
Default Re: H23A...No Mods....What to do?.... (Finest)
Not exactly. The other racers are welcome to buy any car on the track for 1000.00. Winner included. Keeps it cheap.
Old Aug 16, 2007 | 01:24 PM
Si Speed's Avatar
I stand corrected!
Old Aug 16, 2007 | 02:32 PM
flyrod's Avatar
Default Re: H23A...No Mods....What to do?.... (si_speed)
How about one of those ebay megan headers? Might be able to find some inexpensive regrinds on ebay or the H-T classifieds.
How much is your time worth? There are some cheap things you can do to the block, but it takes time to tear down an engine.
Old Aug 17, 2007 | 05:50 AM
hondoval's Avatar
Default Re: (si_speed)
My exhaust is cut just before the cat and ran out the side. Do I need backpressure?
trecius
Jan 4, 2009 07:00 AM
kshgl87
Dec 15, 2006 07:07 AM
efi2nr
Apr 17, 2006 08:56 AM
dflipmode
Apr 15, 2002 06:55 AM
4bidden
Nov 5, 2001 08:13 PM
